done with the compression/(or better yet) leakdown tests? whadya find?
I have a compression tester you can borrow.
I'm getting a set of 275's to use on the ranger for a little bit... I wanna try to make it up THIS sunday.... I'm sorry I missed your call
Any ideas on your misfire? Its ford misfire city....
Re-ran all the vacuum lines, rechecked everything I could, swapped injectors to the other side -- still misfiring on the same side.
After all the Drama.... I had a bad coil pack....
Passed Vac and Compression tests perfectly....
Had the exhaust fixed, runs smooth as silk.... So lame.
haha go figure
