I see failure.
About 70% of wrangler sales are 4 door. The 2 door sells too and I believe they still make it because it's tradition. I like them in both 4 or 2 door, I bought the 4 door because more doors more whores.
To revive the Broncos enthusiasm they will have to make it two door. If this happens, for the price tag, soccer moms would rather buy a 4 door edge or explorer.
If they make the Bronco 4 door, then it will compete with their own line up, the edge, the escape or the explorer.
Regardless of how capable the Broncos is, soccer mom's want 4 doors. Unless they make it 2 and 4 door to compete directly to the wrangler.
This Bronco is going to be another 2002 Thunderbird / Mercury Marauder fiasco.
It should be noted, that the Explorer that is set to come out, will be RWD based again with a 4WD option, but likely independent suspension all around.
Hard to believe they'll go RWD and offer the 3.0 TT v6
Already confirmed the Explorer is going RWD/4WD
Source?
The Explorer is expected to ride on a rear-wheel-drive configuration but offer all-wheel drive. This configuration is expected to be the same one Lincoln uses for a revived Aviator, which the Ford luxury brand will likely use to replace the unloved MKT.
Wouldn't call that confirmed.
We were the first to tell you the next Explorer would be rear-wheel drive. Now, thanks to TTAC’s Blue Oval sources, we have details. The Explorer and its Lincoln counterpart will be built on Ford’s new modular CD6 platform at the Chicago Assembly Plant
I've seen the power train, it's rwd.Wouldn't call that confirmed.
So did they redesign the 3.0 TT v6 to be longitudinally installed?
Interesting. RWD 400HP should make for a fun kid hauling Explorer! Makes me sad we have to go Expedition for wife's next car.
2018? 2018s are bad ass man
