EVAP delete
m_dogg
Brookfield
Trying to clean up the engine bay and remove EGR and EVAP. EGR is simple, not sure how to do EVAP the right way. Purge solenoid has 2 vacuum ports, 1 goes to the TB other goes all the way back to the EVAP canister. I'll be installing Northstar TB so the vacuum source will be eliminated as I don't have the vacuum fitting on the TB adapter. What to do about the line that goes back to the canister? Do I plug it or just leave it? Had it done on my '04 and if memory serves me right I saw it just moved on the side with the electrical connector but can't tell for sure is it was plugged or not.
Thanks.
Harbor Master
fwiw, in my rats nest, it's just unplugged near the firewall iirc.
m_dogg
Brookfield
Went through old pictures of my '04 and it did look that way, wasn't sure if guy plugged it though.
