Engine Shop that knows 3800's in chicagoland?
TurboTPI
Bensenville, Il
I know 3800's are a different animal compared to your typical SBC. Any machine shops that have experience with 3800's in the area? Near O'Hare?
Harbor Master
jokes aside, what are you lookin' to have done? [MENTION=13389]TurboTPI[/MENTION]
TurboTPI
Bensenville, Il
I think i melted a piston in my regal. Im in the process of tearing it down now. But i may have a shop assemble the short block with new parts. Ive already built one L67 and it spun a rod bearing after 5,000 miles. And ive heard nothing but horror stories about 3800's. That once you unbolt the main caps they never live. Long story short, after the L67 spun a bearing i bought a low mile L26 and put my ported heads, cam, blower, ect on it and it ran awesome. Till last week when something let loose. I think its a broke piston. I just dont want to go through all the work to assemble another engine and it spin a bearing again.
Harbor Master
you're against the typical- "find a junk yard motor and throw it back in untouched" route?
TurboTPI
Bensenville, Il
Not against it, haha. Just weighing my options. I have a good set of rods and pistons from an series 3 L32 that id like to use to put a solid short block together.
Harbor Master
Other's should chime in but, I guess i've just never heard of a story of an engine shop built 3800 holding together...
10sec
Yea, rebuilt 3800's die and with the labor you'll spend at a machine shop you could probably buy 4 used motors. So, go the used motor route, don't try to rebuild it. Unless it's just a cracked ringland and has done ZERO other damage other than that, just toss in a new piston. That can be done without tearing the entire motor apart.
Why did you melt/chip a piston? Bad tune or something?
daturbosix
Forum Sponsor
i vote for good running short blocks.
put the money in heads and valvetrain & gen V blower on e85
daturbosix
Forum Sponsor
but.. north west side, see if speed service is interested in touching that. i doubt it, but theyre good at what they do.
daturbosix
Forum Sponsor
powder metal rods? i forgot whats in those..
if you re-bearing them, 95% of the time, they require re-sizing.
daturbosix
Forum Sponsor
tim, save yourself the headache and get yourself a good used short block.
GTPpower
Nebraska
Just get a junkyard block. Keep it from detonating and it will handle anything you can throw at it.
daturbosix
Forum Sponsor
^^ that...
dont forget. the series 2 & 3 3800s are WAY stronger than a 109 casting 3.8 that was in grand national.
TurboTPI
Bensenville, Il
Im not sure why it happened. Ive been on the current tune for close to a year now. I was in the middle of a three way race (2000's mustang gt and 5th gen camaro ss) I pulled on the mustang with ease, then the camaro came up next to us and we did a three wide pull on RT 83 and at the top of 2nd gear i felt my car kind of loss alittle power then a huge cloud of smoke and oil everywhere. It blew the dipstick out and covered everything under the hood in oil. I think it could be that the fuel filter is clogged. When i went to e85 i changed the filter after a few tanks of e85, but that was over 2 years ago. Of course i pulled my wide band 02 out a week earlier. But atleast i was winning when she let go. haha
CHI2000GTP
Grand Prix Junkie
Chicago, IL
I see it's not necessary but I'll chime in anyway.
Do NOT rebuild. As soon as you touch the main caps, 3800's lose their magic.
Get a used block.
10sec
Sounds like you cracked a ringland and all of the combustion was leaking straight to the crankcase. You might have chipped a couple pistons from the sounds of it. It also sounds like the car went lean, so I can only assume you're still running a stock pump?
Also, what are the mods to the car if you don't mind me asking and who tuned it?
