đź’ˇ Fun fact. Whenever you start a thread, TCG Mechanic 5000 (our AI bot) will reply to you to start helping. It doesn't know everything and it will struggle with more complex questions but it can get the thread going and provide valuable information. You can choose to disable it prior to submitting a thread.
Many Marauder owners have already replaced their engines. What is the consensus for the best value, componets & mfg. for a street motor s/c at 9-13 lb boost ?
In a heavy MM sporting a low boost application I would stick with the aluminum block along with a high compression ratio. There are alot of builders out there, they all offer something diffrent. I would look into the JDM stroker short block. Its priced right, its fully forged, and you get a new Mach1 block. Did I mention they also have the right price.
