Engine replacement
Burt Ragio
Many Marauder owners have already replaced their engines. What is the consensus for the best value, componets & mfg. for a street motor s/c at 9-13 lb boost ?
musclemerc
In a heavy MM sporting a low boost application I would stick with the aluminum block along with a high compression ratio. There are alot of builders out there, they all offer something diffrent. I would look into the JDM stroker short block. Its priced right, its fully forged, and you get a new Mach1 block. Did I mention they also have the right price.
http://www.modularfords.com/forums/f64/jdm-302ef-stroker-shortblock-special-178753/
Next in line I would look into Modular Performance or Livernoise short block.
Send your stock heads out for freshning up and install a degreed/advanced set of 96 Cobra cams while your at it.
