Engine rebuild.
RacerX
116
So I had my engine builder bore out the last Marauder Wap block off the line (Ken sold it to me cheap before he knew his was the very last Marauder off the line!) and clean it up. I had him do all machine work, measuring, parts ordering, etc. Picked up the parts. Learned how to file fit rings. Broke a second cast ring...:ugh: Never squeeze them together even gently, they snap REAL easy. Ordered Spares from Arias and finished up. 301cid stroker, .020 over, 9.2:1cr, FR500 ss valves/springs/followers, ported heads, Crower Stg 2 sc cams... The MMR iron block only has 5k on it and nothing wrong with it, but, it wasn't built for what I plan on doing to this one eventually.
Gratuitous engine porn:
Spiral Locks are Soooo much easier when you pull them apart!
A BIG thank you to Rob!!! Dialed in right about where I wanted it, 108/118
Got a deal on this an Innovators West damper.
Found out why my 1 to 2 shift became so soft!!! Had a ne Sonnax locking spiral ring already jic though.
Minus 80+ lbs in the nose now!
RacerX
116
Thanks guys! Travis, even the creeper bit me twice! I was working on adrenaline and just felt a pull. Left some marks though! LSA is 113. LCs are close to 108/118. Zack, I love going from one level to the next. It's even sweeter when you do it yourself. That turbo must make some good ear to ear stretch marks. Oh, finally hammered down today, Jesum h wtf! These tires used to stick!? Happened to be in Guadalahara. :)
P.S. I'm cloning the local dyno shop's hard drive to an SSD drive right now. If all goes well, I'll get it to the owner when they open... Nine hours, maybe get her strapped in if there's a slot... Oh yes, barter!
RacerX
116
Interesting tidbit! Previously with the ported Eaton (stock upper and 6lb lower) I was getting 14psi. Now she only hits 12psi yet has more tq and hp (sop is accurate when obvious as hell!). Now I need to get weldcraft widened rims! She's definitely breathing better with the cams, valves and heads! Dyno scheduled for next Saturday. Alex wanted me to put more mileage on the engine. Only 138 miles as of tonight!
massacre
161
The drop in boost is totally normal in this situation, Bill. With the added displacement, ported heads, cams and LSA, it's not unusual to see a drop in boost pressure but no loss of performance in these situations.
It was great to swing by and degree your motor, and those Cloyes adjustable gears are great, can't wait to order a set. Back when i got into this grinding the keyways was the only option lol. The adjustables saved so much time and aggravation that they are well worth the money!
I am thrilled that the car is running great and that you are happy with it. So far every motor that I have degreed has made power, most was 80 wheel on a big boost centri-blown 2v with WAP block and TFS heads and blower cams. But that engine was built wrong the pass side cam was off by 6 degrees and the drivers by 2 in the other direction.
The last cam on your motor took a little longer because the foot on the dial indicator was getting hung up but we changed the foot and all was well. I'm glad you got to see the process Bill, I mean once you see it done it's a lot less confusing than the descriptions you can find here or there.
Let me know about that ported intake lol ;)
massacre
161
Sure, Travis!
It's an 18" Moroso Pro-Wheel. The bigger wheel is more accurate and about a hundred times easier to read and use than the little wheels.
Moroso now makes a two-piece Pro-Wheel, I looked into that and it just seems needlessly complicated. The outer piece of the wheel is supposed to give you the centerline without having to add together and divide by two. I see no value in that and it seems a waste of money to me.
I've timed a lot of motors with the 18" Moroso wheel, and it has always worked flawlessly. I highly recommend getting one to anyone who is going to degree cams.
http://pitstopusa.com/i-5059435-mor...and-use.html?gclid=CNrom4-6tLgCFTF04godphEAQw
RacerX
116
Travis, check this out:
