Actually I just loaded it this morning. Only thing I can report is the trans shifting is way improved. Stock it wants to shift really early and tended to sit at low rpm in a higher gear when you are part throttle. Now it's nice and snappy and shifts at a higher rpm.
The Trifecta tune is nice. It uses the cruise control to set the drive mode. So Leave the cruise control on (but not active) and you are in daily drive Eco mode. It shifts nice and will move when you get on it. Turn cruise control off and it goes sport mode and holds more RPM and really wakes up.
So on my way home today I took a couple WOT logs of the tune. Its commanding a leaner Power Enrichment to around the 11.8-12.0 AFR vs the usual uber rich 9.8-10.5 AFR stock commanded. Also the Timing table must have been tweaked because the truck is seeing 26-27* timing at WOT vs 24-25 WOT. This is on Premium fuel which I will continue to use on the truck. Its not required for the tune but will perform best on Premium and even on the stock tune I noticed more Knock Retard on 87 vs 93 octane.
[MENTION=11347]ragingclue[/MENTION]
