Emerballs' Chevy Colorado
EmersonHart13
Member Selfie
2017 Chevrolet Colorado Z71 Truck Extended Cab
Exterior Color : Red Hot
Interior Color : JET BLACK CLOTH LEATHERETTE
Engine: 3.6L DI DOHC V6 VVT w/Tow/Haul Mode
Radio: AM/FM Stereo w/8" Diagonal Color Touch Nav. w/ SiriusXM Satellite Radio
Bose Premium 7-Speaker Audio System Feature
Heavy-Duty Trailering Package
Integrated Trailer Brake Controller
Transmission: 8-Speed Automatic
4WD
2017 Chevrolet Colorado Red Z71 4WD. 4WD 8-Speed Automatic V6
Convenience Features
1-touch down Driver vanity mirror Tilt steering wheel Auto-dimming rearview mirror Air conditioning Front beverage holders Speed control Illuminated entry Rear door bins Telescoping steering wheel Rear beverage holders Automatic temperature control Power windows Passenger door bin Remote keyless entry Overhead console Passenger vanity mirror Driver door bin 1-touch up Emergency communication system Navigation system
Off-Road Capability
Ground clearance (min): 211mm (8.3")
Entertainment Features
Speaker type: Bose Primary LCD size: 8.0" Premium audio system: Chevrolet MyLink Radio data system Wireless phone connectivity: Bluetooth AM/FM radio: SiriusXM 1st row LCD monitors: 2 Speakers: 7 Steering wheel mounted audio controls Turn-by-turn navigation directions: OnStar Turn-by-Turn Navigation
Seats and Trim
Heated front seats Max seating capacity: 4 Rear seats: jump Front seats: bucket Front center armrest Power passenger seat Power 2-way driver lumbar support Power driver seat Power 2-way passenger lumbar support Split folding rear seat
Warranty
Basic warranty: 36 months/36,000miles Roadside assistance coverage: 60 months/60,000miles Maintenance warranty: 24 months/24,000miles Powertrain warranty: 60 months/60,000miles Corrosion perforation warranty: 72 months/100,000miles
Specs and Dimensions
Compression ratio: 11.50 to 1 Engine horsepower: 308hp @ 6,800RPM Front headroom: 1,052mm (41.4") Rear legroom: 726mm (28.6") Payload: 678kg (1,494lbs) Turning radius: 6.3m (20.6') Exterior height: 1,786mm (70.3") Curb weight: 1,984kg (4,374lbs) Front shoulder room: 1,461mm (57.5") Wheelbase: 3,259mm (128.3") Exterior body width: 1,887mm (74.3") Towing capacity: 1,588kg (3,500lbs) Engine bore x stroke: 94.0mm x 85.6mm (3.70" x 3.37") Rear hiproom: 1,326mm (52.2") Rear headroom: 932mm (36.7") Front legroom: 1,143mm (45.0") Exterior length: 5,403mm (212.7") Engine displacement: 3.6 L Engine torque: 275 lb.-ft. @ 4,000RPM Rear shoulder room: 1,455mm (57.3") GVWR: 2,540kg (5,600lbs) Front hiproom: 1,397mm (55.0")
Body Exterior
Door mirrors: body-color Trailer hitch receiver Rear cargo: tailgate Power door mirrors Trailer sway control Bumpers: body-color Rear step bumper Skid plates
Powertrain
Mode select transmission Fuel economy city: 17mpg Horsepower: 308hp @ 6,800RPM Cylinder deactivation Fuel economy highway: 24mpg Transmission: 8 speed automatic Variable valve control Engine liters: 3.6 Rear locking differential Manual-shift auto Fuel tank capacity: 21.0gal. Fuel economy combined: 21mpg Cylinder configuration: V-6 Recommended fuel: Regular Unleaded Engine location: front Torque: 275 lb.-ft. @ 4,000RPM Variable intake manifold Drive type: four-wheel Number of valves: 24 Limited slip differential
Safety and Security
Traction control ABS brakes Electronic stability Perimeter/approach lights Security system Dual front side impact airbags 4 wheel disc brakes Panic alarm Overhead airbag Occupant sensing airbag Ignition disable Dual front impact airbags
Suspension/Handling
Front tires: 255/65SR17.0 Rear tires: 255/65SR17.0 Wheel size: 17" Speed-sensing steering Tires: all-terrain Front wheel independent suspension Front anti-roll bar Power steering Alloy wheels
Lighting, Visibility and Instrumentation
Tachometer Fully automatic headlights Trip computer Delay-off headlights Display: analog Variably intermittent wipers Rear window defroster Low tire pressure warning Outside temperature display Exterior parking camera rear Front fog lights Front reading lights Compass
EmersonHart13
Member Selfie
7k so yes. Thankfully! Because we all know that's coming.... ducking junker
DanJoy
Congrats. Definitely really nice trucks if you don't need to do any serious towing. My dad has always had Silverados and F-150's, then realized all he ever tows is fishing boats or an ATV so he got a Canyon this time around. My only gripe is that the backseat leg room is a bit lacking, but if you don't regularly have backseat passengers it's not a big deal.
guspech750
Guspech Superdriller
North Aurora
Those are nice trucks and look great. My boss bought the diesel version and absolutely loves it. Loves it way more than any of his previous full size trucks he's owned. He drives it around the country on his yearly trips and always brags on the 30something MPG's he gets. And it's been trouble free too.
Good stuff.
EmersonHart13
Member Selfie
7k towing is getting into homeowner serious towing imo. The diesel (only available in CC) gets it to 7700. I grabbed the towing package and integrated brake controller so I'm ready for just about anything we would throw at it at this point and the near future.
I'd have been open to the baby dmax but you cant seem to get it in the extended cab unless you go zr2 which reduced towing from 7 to 5 and payload from 1600 to 1100...If I have my numbers right. MPGs are also significatnly lower on the zr2. And since this will pretty much be a mall crawler for my bradozer wife we just don't need to go there.
Thanks everyone. She is pumped, maybe I'll see the keys sometime in September!
So ends up with bye bye to the crazy #failfinity saga! I have more GMs in the driveway again, WOOT! I am now driving the GTO and MS depending on my mood.....
tinfoilhat
Riding the Hubble
The backseat is a joke and shouldn't even be considered a seat.
Outlaw
Johnsburg
Sweet! Congrats. Did you factory order it is or there some other outlying factor keeping you from getting it until September? I'd love to factory order a vehicle once but I fear if If I did that it'd probably show up and I would've bought something else by then.
EmersonHart13
Member Selfie
Sweet! Congrats. Neat you factory ordered it exactly how you want it. If I did that it'd probably show up and I would've bought something else by then.
We bought it off the lot. I emailed every dealer in Chicago to find it exactly how we wanted it. (Basically it is a fully loaded z71) The wife's color choices were the hardest part (red and blue) coupled with they mostly sell Crew Cab trucks and we don't think those look as good as the extended cab. We don't have kids and back seats are either for our nieces or emergency.
September?
Oh I won't get the keys because they are FIRMLY in my wife's hands.... The truck is in my driveway and it is, in her words: "HERS"
Outlaw
Johnsburg
The extended cabs look infinitely better for sure.
Plus the crew cab with the longer bed is pretty much a full size truck length wise, at that point I'm getting a 1500 just for the interior room.
EmersonHart13
Member Selfie
Yeah this thing tucks nicely into the garage, huge plus for keeping it nice.
RICH17
Dr. Pussy Slayer, MD
The 007
Nice man! One of my customers bought one of the first ones out there and have had a handful of little annoying problems. Hopefully nothing comes up like that for you guys
EmersonHart13
Member Selfie
Rich17Thursdays
CMNTMXR57
GM & Holden Nutswinger
I approve of this massage... Now she has something to haul her big colorful cock.
Were you able to work out the discount? Sorry mine wasn't working.
DanJoy
:rofl: We just got back from vacation and I only rode in the back on the way to dinner, and to go fish a different lake. It was fine for that but I wouldn't want to sit back there for hours on a long trip.
