I'm used to it. I get blamed for everything. Work, the Wife, the kids... TCG...
Closer pic of that main bearing.
If I had that 1 quick OT is do it.Soooo turbo yet?
Issue is I need either custom manifolds or 750 dollars in manifolds to get started.
I should probably start hunting used and maybe get lucky
Separate upper and lower that for together with a single barrel carb.Does it have a single big manifold or separate ones? I know a guy that can weld some shit it may not look pretty but it will work
Seems pretty straight forward, buy and ask forgiveness later normally works for me lolSeparate upper and lower that for together with a single barrel carb.
I need
https://www.summitracing.com/parts/...UwbHD8O7_im3pBmicJpQCnlpJCVgGsfhoCTmUQAvD_BwE
And
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/173981795488
Plus all the other stuff.View attachment 41481
That will likely happen over winter. I just space it out and no biggie.Seems pretty straight forward, buy and ask forgiveness later normally works for me lol
*cough* Trailblazer 4200The motor isn't coming out. If it is something else is going in instead and I don't have that available right now. Really I just need it to stop puking oil.
Hahaha. I accept your sponsorship!*cough* Trailblazer 4200
Trust me. I support you. Go get em buddy.Hahaha. I accept your sponsorship!
hey this sits good.
i await turbo noises.
Oil pressure is currently good per very accurate dash gauge and the engine runs well enough though a Turbo would make it better.
did you just go with RTV to seal it up ?
