electrically butt fukked
BoostJunki3
Slow M90 Setup
Plainfield, IL
hey guys my friend has a gtp that is electrically fukked.....his hvac get no power at all most of the time.....sometimes it flickers really fast in and out when the car is first on then dies out....the wires behind the hvac have been cut and wired back together so i checked them all and they are matched correctly....dunno why someone cut it but whats your guys' guess im stumped all fuses are good...anyone know which color wires on the hvac harness supply the power and ground? does the bcm have anything to do with this because his auto/drl lights are all out of wack too....btw multiple hvac have been tried and they all worked in my car....
02BlueGT
No Fucks Have Been Given
Now apearing in Hanover Park
Most likely Ignition switch, If you don't wanna spend the money on it, follow the link to clean it, a Bad IS will cause electrical gremlins all over the car as the whole elelectrical system runs through the switch, basically the electrical contacts get carbon deposits and start having bad/intermittent connections
http://www.clubgp.com/newforum/tm.asp?m=20670
Ron Vogel
Bolingbrook
You have a 45% chnce of breaking the ignition switch when taking it apart.
If you can swing it (they aren't THAT much)...just get a new one.
I have a cleaned up one in my car, and it seems to be getting a little funny again.
02BlueGT
I cleaned mine, didn't seem that bad, but I've only done the one, I never even looked up the price, it was free to clean, so that's the better option to me :)
Frank Dukes
Rockfordia
i bought a new one.. i was looking at the old one tryin to take it apart just for fun.. and the springs exploded out of the switch everywhere...
there went that idea. just buy a new one from rockauto or somewheres.
Ron Vogel
Bolingbrook
Yup, exacty what I mean. If your garage is anything like mine (shit everywhere) those little springs are about near impossible to find when they shoot out!
Plus the contacts are galvanized. Once they are cleaned, they are never the same, and will corrode twice as fast, so it ends up a semi-temperary fix.
Frank Dukes
Rockfordia
i didnt even try to find them.. it was on my workbench and they flew everywhere.. behind it to the sides... who knows. I was going to clean it and flea-bay it but it went straight into the trash when that happened.
i got a call from Al last night....his 04's ignition switch is dead, worked fine till he got home and went to pull the key out and it wouldnt, called me up later after he "got the key out but now it doesnt turn/start and he can see the switch on the back of the tumblers is broken.
knowing al's temperment.....i wonder what happened first lol he was pissed
Frank Dukes
Rockfordia
geez.. not sure how you do that.. theres a release for the key on the bottom of the column.
he's a wop
ya ever have one of those lady fingers that the fuse is like 1/8th of an inch long? his is shorter since getting his house
SaturdaysGS
Chicago (Southside)
James, mine was doing that. Had a helluva time getting the key out, as it wouldnt actually go completely into OFF, once I did I could get it to turn, after enough finageling for a while I got it to work, and it worked well if you jiggled it right (lol) and all that bullshit. The stealer replaced the ignition switch under warranty when I took it in for other stuff, and the problem came back a couple month later. Did the jiggaling thing and it went away. Who knows with my car though. :fu:
