eaton in the 9's possible?
hj16
Tasty!
Queens
Alot.
Built Motor
Solid Rear
Big Shot of nitrous
Ported
Upper/Lower
Slicks
and even then it still takes a ton of driving skills, much easier to go twin screw to do it.
Maniak
Highland Park, IL
weight reduction
ported eaton (obviously)
nitrous
solid rear
skill
i dont think a built motor is necessary really.
Dragon03
Super hated on
I agree start with a Whipple/KB you will put yourself in better shape heading down the road to the 9's. Besides I stayed with the Eaton....went to a smaller pulley.....went to an even smaller pulley...sent it to Steigemeir.....and ended up with a twin screw after it was all said an done....shes only fast for so long :p :p
hj16
Tasty!
Queens
If you go with the size shot you need to get into the 9s on an Eaton a built motor is a good idea if you want to have some piece of mind
REN#4106
maniak said:
weight reduction
nitrous
solid rear
skill
A friend of mine (Mike Catapano EFI Renegade) ran a STOCK 03 cobra long block with a Kenne Bell 2.4/Kooks Long Tubes/built 8.8/Turbo 400/front suspention(k-member,a-arms etc) and went 9.60's using SCT software.......
using a Stock eaton is gonna be one hell of a uphill battle to try to get in the 9's consitently.....
doodad
stock eaton & full weight, 10s looks easy
but 9s.. i would say weight reducion is a good idea.. solid strong rear, slicks, strong clutch, ported blower with upper/lower combo and nitrous should be enough to get in 9s IMO.
