Excited to see the car sit like this...
I think that extra connector is for the EGR, or if it's a longer lead, it could be for the low oil level sender that would have been in the passenger side of the stock oil pan.
Yes sir that is for the purge valveLooks like it's the purge canister harness?
I remember the ships like that, definitely was "hack'ish" after having the chip installed.Last night I got the chip installed into the EEC. Was a bit surprised at how hacky the chip install felt, but whatever it was the 90s! HPTuners is definitely my preferred method of tuning! I did the inspection on the capacitors and all looks to be good.
Next up with be getting the o2 sensors wired with the new harness, setting timing and idle.
Then I think I'm going to try to weld in the sub frames with my Lincoln 140HD.
