Dyno Tuned my SSEi - 359whp (New VS Cam Record)
TommyGloves
CHICAGO
I went this morning to dyno tune my SSEi at Val's Performance in Round Lake. I made 7 pulls with a best pull of 359whp. Gained 12whp overall with just timing and fuel tweaks from my tune from GLD last month.
All runs were in 3rd gear. I maxed out at 14.5psi (2.8 pulley) with 24* of timing at 6000RPM. (E85 is ridiculous.) The dip in the powerband in the last two runs are a result of me fat fingered the MAF table in the upper cells when I added some fuel. :hs:
http://www.glovertech.com//BonnevilleClub/10.10.09Dyno/10.10.09TGloverSSEiDyno.pdf
I also realized that I was leaning out a little bit after 5600RPMs. Not sure if I ran out of injector or maybe the pump (still stock...but rewired.)
Cool thing is I got home and realized I snagged the #1 spot for the highest HP for the ZZP VS cam:
http://www.clubgp.com/newforum/tm.asp?m=1550443&appid=&p=1
EDIT: I guess I'm number #2 (Still happy)
http://www.clubgp.com/newforum/tm.asp?m=3870847
Turk
Lt. Ron "Slider" Kerner
Nice man, very impressive.
sweeet! yeah the riv is at 24* as well....have you run it with a visible fuel pressure gauge? your pump might not be able to supply enough fuel volume at higher pressures.... i have a real nice mech fuel pressure gauge you can hook up and duct tape to the windshield if ya want.
10sec
Damn tommy! I guess i missed out on our dyno day :tear: Damnit! Congrats on the numbers, that sucker is making some powa! E85 is the shiizzzznit!
Xtant12
e85.. How is that possible, I thought that fuel didnt make that much power??
10sec
lol you thought wrong my friend, i don't know where you got that info but you need to do a little research.
PANDA
FRG
Nice Tom! I think you can still get the #1 spot.
Yeah, specially since they took off the front bumper and let water run into the IC system. Im all about run the car like you do on the street. This was 2 years ago, so ZZP's number is still very impressive.
syP
Not Banned
Downers Grove, Illinois
says the guy who uses DRs at the track :pedobear:
