Dying injector?
Aron
Scared pussy
Having an intermittent problem with a misfire. Car runs and drives fine on cold start, but on hot restarts it misfires as soon as I start it, and SES flashes when driving. Had my codes checked, had a code for cyl 4 injector and cyl 4 misfire. Oh and EVAP too (also have intermittent "check gas cap" message). I got my voltmeter out and see voltage for the pulse, but found no ohms from the injector when hot. When I check it cold I get around 13-14 ohms.
Is it common for an injector to die like that when hot? What is a suitable replacement injector? It's an all stock 04 GTPCG and from what I read it's a 33# stock.
ZephTheChef
Wichita, KS
Make a trip to the junkyard and just get another stock injector unless you're looking to replace the whole set/upgrade.
yeah, its common enough i had to replace one on my CompG when it opened internally
pretty sure i have 5 more in a box somewhere in the garage
98GrandPrixIraqVet
Nowheresville North Dakota
Damn its a comp g i have 6 stock 04 NA injectors sitting in my garage and 6 stock 97 gtp injectors too.
i dont think any of them would work.
im not 100% sure if any of those would work i could mail you some this weekend.
:dunno:
edit james beat me.
Aron
Scared pussy
Cool thanks guys.
James, how much you want for one of yours if I can't find one in my local u pull it? [MENTION=53]Turbocharged400sbc[/MENTION]
Aron
Scared pussy
I put a multimeter on the injector and got 14/15 ohms cold and it ran fine. Drove it, got it hot to the point it started misfiring, got 0ohms from injector. Im pretty confident that is my problem
i found the bad one that i yanked out, the good ones must be nearby if my filing system wasnt fucked up by kevin cleaning
boostedguy05
not well known
:rofl:
now that you have room, i should bring you those tie rod end links and spark plug wires.
