Sweet just sent in request to join. How are you guys testing quickly at the pump? Do you always have a gas can and a bottle of water with you at all times? lol
Find a high-throughput station close to home. Once it hits the summer 83%, it's good for a long time. No need for testing until the fall.
93 is no fun after you feel e85 and lots of boost so once I switch I don’t switch back till storage
If you can't find anything higher than 65%, you must be testing wrong. I rarely find anything below 70%. And I have never found anything above 85%.
By law, it cannot be over 85%. Actually 83% is the highest it can be. The 85% ethanol is fuel grade, denatured ethanol, so its not pure. Any number you get above 83% is most likely test error.
Speedway is often the highest for me. They sit at 83% all summer and are mid-70's in the winter.
1. Scope
1.1 This specification covers the requirements for automotive fuel blends of ethanol and gasoline for use in ground vehicles equipped with ethanol fuel blend flexible-fuel spark-ignition engines. Fuel produced to this specification contains 51 % to 83 % by volume ethanol. This fuel is for use in flexible-fuel vehicles and is sometimes referred to at retail as “Ethanol Flex-Fuel.” Appendix X1 discusses the significance of the properties specified.
1.2 The vapor pressure of ethanol fuel blends is varied for seasonal climatic changes. Vapor pressure is increased at lower temperatures to ensure adequate flexible-fuel vehicle operability. Ethanol content and selection of hydrocarbon blendstock are adjusted by the blender to meet these vapor pressure requirements.
I believe 1quick said that they changed the way they deal with winter blends as well. They use different additives/formulas to keep the ethanol % high and not have vapor issues. Butane was one of the newer ones I believe. I keep forgetting the ones he mentioned. So even with the higher % or E testing the fuel still is not as good as "summer" blends.
Most still use gasoline. It's already at the terminal. Natural gasoline would require a separate storage tank and that's hard to justify for a small throughput fuel like E85.
the terminal I worked at sold the gasoline to the ethanol plants, it was not regular unleaded, the vapor pressure of the natural gasoline is 14, normal 87 has to be under 9 so they dont need to add butane to the ethanol blends since it already has alot of vapor pressure in the gas they just add some more gas and cut the blend down
Where the ethanol plants shipping E85 directly to retail sites? Or were they just using the natural gasoline to denature the ethanol?
Conclusions Ninety-one Ethanol Flex Fuel samples were collected from the continental United States in all Specification D5798-13a classes...This study showed that lowering the minimum allowable ethanol content to 51 vol% (the allowable range in Ethanol Flex Fuel is from 51 vol% to 83 vol%) increased compliance over previous surveys. Two samples exceeded the ethanol content requirements..... The average ethanol content in classes 1–3 was 77 vol%, dropping slightly to 71 vol% in class 4. Compliance
