Drum E85
CobraSki03
Hoffman Estates
Looking to see if anyone has or knows of where I can get some E85 in a drum. I have tested a few local pumps and the best I have seen is 65%. I’m looking to get my final tune done tmrw and need some high grade corn. 5gals is all I’m looking for right now. Any help is appreciated, Thanks TCG
1quick
coal city
You can use c85 but the stoic isn’t exactly the same as pump e85, check the e85 Facebook page I’ve seen people up your way post some 80-90% stuff lately
01Cobra
Johnny Cobra
Speedways e85 always seems to be consistent in the 82-85 range. I’ve tested bp e at 90 before.
b4black
Oswego
If you can't find anything higher than 65%, you must be testing wrong. I rarely find anything below 70%. And I have never found anything above 85%.
By law, it cannot be over 85%. Actually 83% is the highest it can be. The 85% ethanol is fuel grade, denatured ethanol, so its not pure. Any number you get above 83% is most likely test error.
Speedway is often the highest for me. They sit at 83% all summer and are mid-70's in the winter.
CobraSki03
Hoffman Estates
No, it’s not that I can’t find it, it’s I haven’t tested any pumps. The last batch of E85 I got was in jan and that was just to get base tune in car to move around. I don’t have a test kit at the moment (it’s in the mail) but was hoping to get some drum 85 to get track tune. Basically I was not expecting E85% to be as low as it is. I live in Hoffman estates, anyone know of a station near me that has quality E85?
1quick
coal city
I just tested some that I’m guessing was in the 40’s my test tube only goes to 70 but it was well below half, had a 5 gallon can of it multiple test showed the same, my theory on the 90% results is water contamination shows up on the test tube test as ethanol
1quick
coal city
If your getting a track only tune get some vp c85 it’s legit I mix it half and half when I go to the track with pump to keep the stoic closer it’s really not that far off anyway but the gas they cut the ethanol with is race gas so the octane rating is a lot higher and it’s oxygenated, supposedly it makes 5% more power
CobraSki03
Hoffman Estates
Yea I was trying to get my hands on some today, was going to try Winners Circle, Koza Motorsports or try Mana. My tuner likes Ignite E85, but they are in Indy.
1quick
coal city
Winner circle normally has 2-3 cans of it I was getting it there sometimes last year
Pressure Ratio
Glen Ellyn
I have swung down there a couple times to grab a 5 gallon pale or two. Always have had it in stock.
I love how in that FB group guy shows a tube showing like 92%. Then the guys shows his Cobb showing like 82%. You mention the water throwing off the test and people jumped all over you. haha Really? The OP even showed a 10% difference between the tube and the sensor.
I agree, it's either people not paying close attention when the add water & fuel or fuel having water in it throwing the reading in the tube some as well. It's not enough to cause issues obviously. But unless you bring that shit to a lab, we'll never know 100%. Tests over 80%, send it. haha
1quick
coal city
I’m anal about measurements being accurate, I run lab test on liquid polymers at work that I make so I’m used to being on the money, I use droppers from work to fill my tube test for my e85 a drop at a time when I get close to the line lol
Pressure Ratio
Glen Ellyn
lol I use a dropper as well.
You know you have to question someone when you ask them where they read the meniscus and they don't know what you are talking about. haha
EmersonHart13
Member Selfie
I am having chemistry class flashbacks and that isn't good
Bub
Pitter Patter
Pistakee Highlands
I was watching a guy fill his cobra with corn last season while he was testing. Brave.
1quick
coal city
I filled my car and 2 cans last year and thought it smelled weird tested when I got home and it was 50/50 I just took it easy on that tank the knock sensors pull timing if they need to but I only trust them so much, a lot of the cobra guys back in the day would unplug the knock sensors though, I did that on my old turbo Grand Prix but I was mixing my e85 with 110 down to 60% so knock wasn’t a big issue
CobraSki03
Hoffman Estates
I found some c85 closer at Chicago Connection. Going to pick up on my way from work and see what this bitch will do on the rollers. I have never gone through the whole testing of E85 at a pump. So what is your guys process?
fill maybe container with a cup of pump E85, fill your test tube with water to the line. Use a syringe to pull E85 from your container and and fill tube up to line. Shake and let sit for a few mins?
1quick
coal city
If I’m just going around testing I fill a 5 gallon can fill water to the line with fill gas to the line with a dropper I use these little plastic ones so you can do one drop at a time, put my thumb over the top and shake a bit then put the lid on and let it sit for a minute or so, the lids leak on most of them, if it’s shit I feed it to my f150 lol
Jeffs FRC
Carpentersville
E85 locations (USA) there’s a ton of guys from Chicago on it though
Sweet just sent in request to join. How are you guys testing quickly at the pump? Do you always have a gas can and a bottle of water with you at all times? lol
b4black
Oswego
Find a high-throughput station close to home. Once it hits the summer 83%, it's good for a long time. No need for testing until the fall.
1quick
coal city
I fill the tube at home and I’m always filling gas cans so I have a reserve at home I keep 3 6 gallon cans so I can fill the car at the pump and refill it once before I have to hit a gas station, you will most likely be like me with a semi heavy foot on e85 it’s 190 miles to a tank lol
1quick
coal city
When we did that fall trip it was an hour drive to the meeting spot for me I brought a 6 gallon can filled the car in Woodstock did the whole trip up, topped off out of my can at the bbq place up in Wisconsin and made it all the way home on a tank, there’s planning involved but pratt scouted out a high % station for us, 93 is no fun after you feel e85 and lots of boost so once I switch I don’t switch back till storage
