Dragy - GPS based performance box
95SC
4 cams
MI
Anyone here has one ? Very similar to V-box but way smaller and without the crazy price . Pretty small box , I just got one couple days ago . It has a magnetic bottom so I didn't even need to install the double sided mounting plate that comes with it . It sticks to my center dashboard speaker
El Presidente
Ive been seeing Ian raving about it on FB and IG.
95SC
95SC
4 cams
MI
Did couple street hits yesterday. Car did OK for being on 3 year old Michelin Pilot super sport tires
Pressure Ratio
Glen Ellyn
I have seen more and more people using them. I actually ordered one yesterday. But I haven't seen anything on testing the accuracy of the data though. This versus Vbox and so on.
I know on the Porsche and 6SpeedOnline forums they compare the 60-100 & 60-130 times. But they do them from a cruising speed at 60 mph and then let it rip. Your car moves out. But I have seen some of these guys running 4.6-4.7 times with bolt ons. That has to be insane.
95SC
95SC
4 cams
MI
Car has to make over 800whp to get 60-130 into 4's . I'll do a roll today to see if there is any difference . I did couple dig hits yesterday , coming back from work , car was very hot and tires had 38psi . I'll do couple hits on drag radials over the weekend
Pressure Ratio
Glen Ellyn
Well, these have upgraded compressor wheels in the stock VTG turbos. So bolt ons in the meaning they have the restrictive turbine side still. Versus say an AMS Alpha 10 kit with ball bearing turbos, larger turbine side, and external wastegates. But they are probably close to 730-760 whp. Maybe closer to that 800 whp number. The 911 turbo seems to do well with less peak power when compared to some other cars. I am sure due to the great low/mid range power they make. They start pulling hard above 3K where other cars may have to get within 1000 rpm of peak power to really start pulling.
I think most times are around 5.9 to low 6's on pump gas. But on E85 pushing the turbos hard, they can dip in the 4's. Which is just crazy.
I think they like the cruising start at 60 mph because big turbo cars that take a while to spool get shown in their times that way. If you have quick spooling turbos or rolling anti-lag it doesn't much matter.
95SC
95SC
4 cams
MI
Its all about power . There is plenty GTRs into 4s running stock turbo housing with upgraded compressor wheels
95SC
95SC
4 cams
MI
yea but 60-130 is such of stupid measurement. I really don't care about that . it's for very high hp cars or shitty cars that can't get any traction under 60mph. 30/40mph roll is that's where we mostly race to around 150mph
Pressure Ratio
Glen Ellyn
Ya, I get it. I'm not really into the 60-130 times. I would bet the 60 mph start came about from high hp, rwd cars needing to be that high to hook well enough. But maybe I am wrong? I feel it is the same with the 1/2 mile stuff came about because people couldn't hook, or didn't want to damage anything launching it hard, doing a 1/4 mile pass. That allowed them to roll to higher speeds before the went full throttle.
But I guess the 60-130 & 1/2 mile stuff makes it easier to see where cars stand compared to other vehicles. Without the risk of damaging parts or spinning bad when launching the car from a dead stop
Thats actually pretty slick. Where did you find it for $130? I see it on amazon for $150 currently.
95SC
95SC
4 cams
MI
Let me check with my guy . I have bunch of local guys that want one too . I might be able to get even better price then that if We buy few of them at once
:bigthumb: I'd probably be down for a discounted group buy on one of these.
95SC
95SC
4 cams
MI
Air down the tires to 32psi and made couple more hits got 2.81 0-60mph . 3700rpm launch and mid boost in first gear .my worn out 3 year old tires won't support full boost in first gear , 3700 rpms is the max the support too
95SC
95SC
4 cams
MI
10.42 1/4 mile is not bad on the street running Michelin PSS tires
95SC
95SC
4 cams
MI
Looks like my old worn out michelin tires won't 60' any better. Car is still pretty consistent on the street
95SC
95SC
4 cams
MI
If any of you guys want this box let me know .I can get them for $125 shipped
95SC
95SC
4 cams
MI
Has anyone used one of these things at the drag strip to confirm accuracy?
Turbo porsche had the box running during 1/4 mile at the track. Pretty close
95SC
95SC
4 cams
MI
Dragy shows slower 60' and 0-60mph because there is no 1 foot rollout on the box
Pressure Ratio
Glen Ellyn
That is a good sign. And ya, the way you stage can help tha 60' / 330 ' times due to the roll out. But good little box for the money. Compared to say a VBox.
And that stock Turbo S is a beast. lol
95SC
95SC
4 cams
MI
Once you install the app on your phone Leader board and live feed is pretty cool too
95SC
95SC
4 cams
MI
not a bad box for the money
if you look closely he has a mods listed : tuner , DP , intakes
