I’m working on putting together a smallish kit of strongman implements to add some variety to my training.
First things first, it would have been cheaper to buy a pre made steel log press from Titan Fitness for $229 shipped. A real log, log press starts around $500 if you can find one in stock.
What’s the fun in buying something pre made? I’m a tinkerer and if I can build or do anything for myself, I do it 90% of the time. Fabrication is just as fun as the end result for me.
The beginning:
DEEZUZ was kind enough to slice up a section of utility pole for me that he had lying around on his property. 10” diameter, 54” long right now that I’ll cut down to 48”, and i would guess 80-110lbs.
Steel prices are crazy right now. Hopped on SendCutSend and ordered some laser cut plate to make ends for the log to load plates and plates to mount handles inside the log. Naming this the DEEZUS log, and getting the name plate laser cut to recess into the log.
The beginning:
