I saw this video and it really got my wheels turning.
My "race car" also lacks AC and I wish it didn't. I don't necessarily regret deleting the original system though. I did what I had to do to make the turbo system in my Camaro work quietly and remain serviceable. The original evaporator box and compressor had to go, but I did at least keep the factory heat. Here's a LINK to that job for some context.
Now that the car is pretty fun and reliable, I'm trying to achieve more comfort. Bringing AC back would be awesome. I don't expect to find a ton of help here, but I'm curious if anybody has had any experience with 12V compressor pumps. I'm considering mounting one of those and a drier where my battery used to sit and a Vintage Air remote condenser with fan in front of the radiator. Custom hoses will run inside to the simplest evaporator/fan unit I can find which will blow cold air into the original blower motor. Yes, that would be two blower motors and a some interesting fiberglass work to get ducted correctly. This probably sounds like a goofy approach, but like the video I want to use the car's original control panel. To do so, I would probably need to reincorporate the original Camaro pressure switch, and wire the retrofit evaporator in a way that's always on full cool and full fan speed whenever the original control is on an AC setting.
TLDR:
Has anybody used a 12V AC compressor? Have you had issues with quality or performance?
TLDR:
