DIY Car Servicing Ramp
118,581
greasy
36,936
29,032
Those look great, literally your cuts are damn near perfect.
Thanks! They are damn near perfect because I cut all the wood on my dad's radial arm saw. I measured 14" from the blade edge and screwed a piece of 2"x4" perpendicular to the fence that way all the cuts were exactly the same. It also made cutting go super fast.
32vMonte
Car is broke
Dec 3, 2008
774
50
I think you answered my question here, but I'll ask any way. How long did you cut the 2x4's and how many 2x4's did you buy?
Thanks
greasy
36,936
29,032
I just made a set of these and they look very sturdy. They are actually pretty heavy once all screwed together. Will definitely come in handy for pulling a transmission or doing exhaust work. Can't wait to try mine out.
Thanks, will be building these next weekend
Nice!
When flipped over, with the three 2x4's facing up, these make great step stools. When I was installing the CC plates on my car the front end was raised and getting into the engine bay while standing on these was super comfy and sturdy. Versatile pieces for sure.
EmersonHart13
54,243
22,415
I agree, basically it is faster loading cribbing. If you have the space they are genius though. He used engineered I-Beams which is totally over kill. You could get by with 2 by 10s which are much cheaper. Compression loads for wood is crazy high.
Wood Strength
Like 4000 PSI for nearly all species. Cars put down what like 35 PSI? The cribbing you have could easily hold much more weight. If you could balance it one could probably handle the entire car.
greasy
36,936
29,032
Wood Strength
Yeah those engineered I-Beam floor joists are super expensive, but much much nicer than the standard 2 x10's.
greasy
36,936
29,032
I think the key also is that they are way lighter. This guy was running two for the outside and one down the middle. 3 beams adds quite a bit of weight. You could park just about anything you can drive with a standard driver's license on top of that.
Wow, that is crazy! The only downside to that design would be if there was any lateral movement allowing them to collapse. If they are tied together well then that would not be a problem.
