Build a car around this…. 8k+ rpm, naturally aspirated, 750hp
5.2 voodoo, raise compression, borla stacked semi cross intake kit, would bet easy 700 crank hp.
You could go bougie and do the Recaro Orthoped seats… heated and cooled!Sorry I am late to the party here!
I've been bit by the handling bug HARD. After driving WhiteKnuckle 's 2022 SS 1LE on TCG Tour and then 03GTGreen 's 2016 GT350 this past weekend, I am in absolute love with the way those 2 cars stayed planted in turns and absolutely rocketed out of them. What an addicting experience!!! So my initial thoughts were to build a Chrysler Conquest/Mitsubishi Starion with a Hellcat swap, but I don't like the low rev aspect of the Hellcat motor and the weight of the iron block.
So then I started thinking about building another SN95 and dropping a 5.2 Aluminator, swap to a IRS out of a late 99-01 or 03/04 Cobra. I think it will be easier to find a clean SN95, even a V6 car. Motor will be mated to a 6 speed trans, looking to incorporate some type of aftermarket adaptive suspension into the car. I would like to try to do a somewhat modernization to the interior as well, maybe swap in some late model Mustang Recaro's.
5.2L ALUMINATOR 5.2 XS CRATE ENGINE
5.2L ALUMINATOR 5.2 XS CRATE ENGINE|Ford Performance Partsperformanceparts.ford.com
- Designed to work with 2015-2017 Mustang GT electronics-custom calibration required!
- 580 Horsepower @ 7,800 rpm
- 445 lb.-ft. Torque @ 4,500 rpm
- 5.2L
- 317 Cubic Inches
- 12:1 Compression Ratio
- Mahle® hard anodized forged pistons with low friction coating
- Unique Manley® H-beam connecting rods with ARP2000® bolts
- Unique Ford Performance M-6303-M52 Forged steel cross-plane crankshaft
- Uses Ford Performance M-6010-M52B Shelby GT350 cylinder block
- Ford Performance M-6675-M52 Shelby GT350 oil pan which features integrated windage and slosh baffles as well as an integrated oil pickup
- Ford Performance M-6600-M50A billet steel gerotor oil pump gear set
- Ford Performance M-9424-M50CJA Cobra Jet tuned intake (will not clear production 2015-2017 hood without modification). Please contact the Ford Performance Techline for more information
- Ford Performance M-9926-CJ65 Cobra Jet dual bore 65mm bore throttle body
- Four-valve-per-cylinder Shelby GT350 fully CNC ported aluminum heads with Roller-finger camshaft followers
- Unique PAC® valve springs
- Ford Performance M-6550-M52 camshafts
- Camshaft specifications:
- Intake camshaft - 14mm lift / 270 degrees duration
- Exhaust camshaft - 14mm lift / 270 degrees duration
- Robust primary timing chains as used on Shelby GT350R
- Low-leak rate variable cam timing (VCT) phasers
- Forged steel crankshaft sprocket
- Ford Performance M-9593-LU47 47 lb. fuel injectors
- Ford Performance M-12A227-CJ13 high RPM pulse ring
- Unique Ford Performance blue coil covers with added unique badging. This coil cover set is not available anywhere other than the Aluminator 5.2XS!
- Ford Performance M-12405-M50A zero (0) heat range spark plugs
- Ford Performance M-6731-FL820 oil filter (quantity-1 included)
- 200 amp alternator and Front Engine Accessory Drive (FEAD) kit as used on the Cobra Jet race car
Mustang GT | GT350 | GT500 RT DDA Coilover Kit | DSC Sport
www.dscsport.com
Optimal therapy: sitting correctly - Orthopaed - RECARO Automotive
Aftermarket seat RECARO Orthopaedwww.recaro-automotive.com
The only thing Mikey’s car was missing… cooling my balls while beating the shit out of it. The HellYACHT took care of that missing aspect.See I love the modern aspect of that and would love to incorporate that!
I have yet to sit in one. But awhile back was watching a vid on them. Some retailers were basically just stripping them down to the bones and redoing them completely with thicker bolsters and such.Too bad they can make the Speed V with that! Have you sat in the Orthoped? I want them to hug me like those Speed V's!
AC is a must in this build, I want to be able to cruise a weekend if it is balls hot out and not be a sweaty mess.
