Diagnosis for rumble?
I'm on my way home from work today and after some stop and go driving because of a broken down semi on Harlem, I get past the congestion and start accelerating up to around 55. Just gentle acceleration, not even half throttle. As I go past 40, I feel a strong rumble that seems to be coming from the back of the car. I turned onto side streets and had no problems driving under 30 mph. Stopped and looked at all 4 wheels but didn't see anything wrong. Looked under the car but no errant fluids or obvious damage. Started for home again driving slowly and testing the car. When I would get up to around 35, the rumble would start again. Motor seems fine. Trans seems fine. Doesn't matter which gear I'm in. I may have felt a little side to side shimmy but it could be my imagination. I'm guessing wheel bearing? Could a bad bearing make the car rumble? Anyone had something similar happen to them or know what it could be?
ShelbyGuy
Turgid Member
yes. a bad wheel bearing can cause rumble. you know how to adminster the test...
...well??
I'm working 7 days this week, mopstly 10 to 12 hour days so I haven't had much time to look at the car. I'm typing this while on the way to Rockford for a job. I did jack up the rear and didn't find anything obviously wrong. I will take anopther look after I wake up tomorrow.
ChicagoMike
wheel weight fell off a tire, or they are worn to where they are out of balance. rebalance rear wheels.
that's my guess
that's my guess
Hi Mike. No, it's way more vibration than a wheel weight would bring. It also happened as I was driving so it wasn't a gradual going out of balance. My guess is either a wheel bearing failed or there's something wrong somewhere in the rear end. I could see it being a broken belt in the tire but the car runs fine up until 30 mph so I'm just not sure what it is.
The car is at Sutton now so I will hopefully hear what is wrong tomorrow or Monday.
blubyu
I've had similar sensation with worn out ujoints. More when torque is applied than when decelerating.
Maybe it's your landing gear?
:laughing2
