Do you have a hp goal for this new set up?
Also Ken bjonnes is the man doing the tuning not Aed. Just want to make sure I give credit where it's due.
In for used turbo kit........
Didn't you buy a complete long block from Ford? Is it rated for your boost levels? I would think so, why not see if they will replace it? Maybe I don't understand the entire situation so I am just thinking out loud. Hate to see this happen to you.
I did buy a complete long block. Changed out the springs and crank sprocket. I'm sure once that motor was cracked into any type of warranty is out the window. Thought the Aluminator's were good to a thousand to the wheels that's why I left it under thinking I'd be ok for a while. Now I'm starting to hear head studs should be used after 850-900. Odd, I hear all these other guys running 9-950 on stock blocks with no issues.
Wtf
