Damn break pedal is burpin sometimes
Freebeer187
The Bolt Rounder
Schaumburg
This has been happening ever since I got the car but not this bad. For the past couple of months sometimes the break pedal will act like there is "low traction" and the pedal will start pulsating at very slow speeds (15 mph or lower). It doesnt necessarily effect stopping, BUT it is very annoying and there obviously is a problem. Not to mention the damn abs light has a mind of it own and is on 40% of the time... Im pretty sure ive made posts of this before but I cant seem to find them.
ALSO! ive been meaning to make a post about this. Does anyone notice when breaking aggressively to a sudden stop there is an annoying down shift that kind fucks up the flow of breaking? Kinda hard to explain but ive almost know to ease off of the break because I know a down shift is coming. The reason I ask is because maby its something with my tune? Dunno but im scared of the 3800 trans
PANDA
FRG
Get the car scanned when the ABS light is on and see what the deal is.
raygtps
World ain't what it seems, is it gunny?
HP IL
Could be the O rings in the master leaking down on you, my friends 02 GTP had similar problems and after I replaced the master the brakes have been better then ever.
Freebeer187
The Bolt Rounder
Schaumburg
Yeah its getting worse. Especially if the car is facing down hill and I am braking. Really getting annoying. Any other suggestions?
Can Vato zone do this or do i have to take it to the dealer?
What signs should I look for the assume that this is the problem?
raygtps
HP IL
Where in Schaumburg do you live? I live between Irving Park Road and Schaumburg Road.
I P.M.ed you my number, if you want give me a call and you can stop by and I can take a look at the car.
Ray
02BlueGT
No Fucks Have Been Given
Now apearing in Hanover Park
I had this when I had a failing Wheel speed sensor, the car thought that wheel was locking up, and triggered the ABS... That is where I'd look first
ls6velless454
Wheel speed sensor will def. yield these results and the fact that you have the abs light on just further reinforces that.
AlmightyBirdman
*shrug*
Detroit Rock City
I agree as well with the wheel speed sensor. I'm pretty sure that vato zone scanners will work. Go get it scanned and then post up whatever codes you get in here.
