Coyote owners - we can now offer Boundary oil pump gears and sprockets
117,578
Okay, now that I have a better idea of the direction Im going to go in, can you shoot me pricing for the following Boundary items Mook Mook ???
Assembled Coyote Oil Pump - Part # CM-S1
Coyote Oil Pickup Tube - Part # CM-PT
Coyote Crankshaft Timing Sprocket - Part # CM-SP-15
We can get the first and third. The 2nd one is special order with no lead time listed. 95SC 95SC, are you able to get the pickup tube from another source?
117,578
Reactions: FESTER665
FESTER665
39,951
66,070
Can I get a quick schooling of why this is important for a coyote?
The factory gears were known to crack which is no good for a gear driven oil pump obviously.
From my research it appears the problem was most prevalent in the Gen1 Coyotes, literally people would drop them and they would crack/shatter. It sounds like the problem isnt nearly as bad in Gen2 and Gen3 models, but it's cheap insurance if you're planning on beating on things a little more than a stock one would.
Reactions: GLADIATOR
