codes?
SLASH
God bless our troops.
Jun 20, 2005
11,024
p0127...ignition sensor too high
p0234...engine overboost condition
p0230...ignition/dist engine speed input circut malfunction
p0352...ignition coil "a" primary/secondary circut malfunction
p0352...ignition coil "b" primary/secondary circut malfunction
p0353...ignition coil "c" primary/secondary circut malfunction
p0354...ignition coil "d" primary/secondary circut malfunction
p0355...ignition coil "e" primary/secondary circut malfunction
p0356...ignition coil "f" primary/secondary circut malfunction
p0357...ignition coil "g" primary/secondary circut malfunction
p0358...ignition coil "h" primary/secondary circut malfunction
p1229..elec throttle control circut.
the problems i am having are related to either ignition or mechanical, possibly valve springs or whatever, i was dropping off considerably top end, evident in my run...any options/ideas. these codes kinda solidify the ignition possibility???
input please
01Sleeper
3,667
1,895
Didn't you just get a boost a spark? If so, I would start there, since it is EVERY cylinder
p0358...ignition coil "a" primary/secondary circut malfunction
input please
VenomInside
Just Grazing
Jul 16, 2004
26,043
3,929
SAC/DEN/SFO/CHI/SEA/PDX
BAS and those expensice coils are not worth it for these cars. It has been proven that these mods do not gain any power. All it does it let you open up the spark gap a little bit. I'm not running one and doing good. Id ditch the BAS. just my .o2
Kevin
+1
When i had my 2.4 I only ran a BAP but never a BAS. There was no need for one.
