Cobra Has Bad Belt Squeak!
Stangfreak91
My buddy's Cobra has a real bad belt squeak that won't go away! He's changed the belt, and has changed all the pulleys to BF pulleys and still has belt squeak? Any ideas??
Thanks
Oncebitten03
you sure it's the belt? did you take off the blower belt and run the car? i thought that too once but it was an a/c compressor
Wiked03
CSVT OG
Louisville, KY
Yeah I would try running the car without the blower belt and see if it goes away. If not, maybe it is the tensioner.
Mr. Unknown
New member
Is it a constant squeak? I had a problem with my 2.93 and a 100mm idler. it would squeak and almost tick when the car was cold. But when the car warmed up would go away. I took it to speed inc and they removed the idler and put a small belt on. I don't know if that helps or not. Just some info.
SonicBlur
Harvester of Sorrow
Schaumburg
What brand belt is it? I had a Gates belt and it was LOUD as all hell. I put the Good Year Gatorback and all is quiet. Maybe that might be the issue...
-Mike
Stangfreak91
Stangfreak91
He's using a Gates belt right now, He says that once the car warms up it goes away. Right now just trying to pinpoint where the noise is coming from,
I'm thought that it might be the tensioner.
SonicBlur
Harvester of Sorrow
Schaumburg
Tell him to try a Good Year Gatorback belt. Gates have been known to have noise issues. It's only $20, and if that cures it then it will be well worth it, if not, you have a spare belt handy...it's a win-win test.
-Mike
Stangfreak91
Stangfreak91
-Mike
thanks! i will tell him.
batman
Surrounded by 10 points
make sure it the right size and it isnt rubbing
SnakeBite2k3
Pray For The Dead To Rise
Mine make allot of noise as well but when it gets warm it stops. I thought you shouldn’t use gatorback belts with non slip pulleys?
ShelbyGuy
Turgid Member
Make sure its not the bearing on the tensioner's idler pulley. It only makes noise for a little bit before it shits itself.
Wiked03
CSVT OG
Louisville, KY
That is BS IMHO. I ran a gatorback with my BF non slip upper pulley for 20k miles with no issues. I would bet people were using the wrong size belts if they had issues.
cdh027
I agree. I've been running a 2.80 non-slip upper with a Gatorback for 3 years now.
Stangfreak91
Stangfreak91
I have a 2.8 upper from Reicard Racing and I running a Dayco Polycog belt and have had no problems as a matter of fact I've got a bonus whistle that sounds pretty cool at low speeds.
I think what happen with him was that on the dyno he had the SC expansion tank packed with ice and when they drained it on the dyno some of that fluid got on the lower pulley and belt possibly causing the squeak, So we will start there tonight , will run the car with no belt, If there is no squeak then clean all the pulleys with brake fluid and put on a fresh belt and hopefully that will solve the problem. IIf not then we will goto plan B? Which I don't even know what this is right now.
Thanks Guys!
gnxs
Corn-Fed Goodness
I've got a squeeky belt problem myself right now. Same deal...it goes away after everything warms up. I'm going to take the idler off tonight and see if that affects it. I still haven't been able to isolate the issue. :mad:
DSG03COBRA
Plainfield, IL
Hope that's not the case. I was going to post up about a similar squeeking problem that started recently. I haven't had the chance to try and diagnose the cause yet, but the only change I've made is installing a RR Tensioner. If that thing is going, I'm gonna be pissed...
Sorry, now back to the original thread creator's problem... :-o
99 Stangbanger
Phantom Fury
Tensioners will sqweak at first then tick once they crap out. Bet its his belt choice though. LIke the one guy above said, swap out the belt for a GoodYear and work your way to the Tensioner. Its either or imo.
SonicBlur
Harvester of Sorrow
Schaumburg
If it's not the belt, then I'd blame the tensioner (mine was bad too), and if it's not those then I'd pass the blame onto the idler pulley bearings (in which case, just call BilletFlow and Doug will ship out a NEW bearing free of charge!)
As far as the tensioner, you WILL NOT BE ABLE TO BUY JUST THE TENSIONER FROM FORD, IT COMES AS AN ENTIRE PULLEY ASSEMBLY THAT COSTS $600!!! However, John (ShelbyGuy) says that the tensioner off of a Lightning might work, as it is pretty much the same. Give those a try. Good luck.
-Mike
Dragon03
Super hated on
+1 Im in agreement. I run GB no problemos
Dana
Bluesmobile
As long as you are taking the belts off, try spinning the alternator by hand and see how it sounds. They go bad, both the alternator and its bearings on a regular basis.
You may also be able to hear it with a long screwdriver or something similar.
Do not use brake fluid to clean anything if you value you paint.
Dan
