CNC staging brake or line lock or Trans brake
DynaSlim
Plainfield
What's best? I'm assuming Trans brake for auto cars but what about the staging brake vs line lock? Today was first time I've heard of the cnc staging brake. I looked it up bu it seems useless compared to line lock.
1quick
coal city
cut a hole in the floor and use your feet to hold it back, or have someone stand next to it and put a stick in your spoke untill your ready to leave then pull it out real fast
ProjectGTP
And why are u comparing a trans brake to a line lock?
ProjectGTP
This, no one I know of launches off a line lock, just use it to do the burnout.
Only thing I could think of, is if the car is stick and you don't want it to roll while staged. Idk.
ProjectGTP
So I've got maybe half a legitimate answer?
Do u have an automatic? Line loc is for doing a burnout basically. Trans brake is for an automatic. It basically puts the car in 1st gear and reverse at the same time(acts like neutral). Then when u let off the button or whatever it slams into gear. Basically like neutral dropping, except safe for the trans. People usually use a 2 step of some sort with that.
ProjectGTP
Staging brake is the same concept as line loc. With a stick car u can preload the suspension a lil before launching. From what I looked up at least. I guess its more for fwd cars.
