Not worth a million bucks but looks rot free. It was the 301T wasn't it?
You may be lucky enough to find a person trying to race a class that needs an "OE turbo car" For a class.
It came with and without in 80 and 81. 81 was the first to get a computer to help. Mines without a turbo so I have the shaker hood. Turbo has the big offset on the hood.I was today years old when I learned the 80 TA was turbo'd
lol yeah, I've always heard that the turbos were more of a novelty on these than anything else, but I've never gotten to ride in one to make my own judgement. If the 80 models didn't have any sort of electric ignition timing then how did it compensate for boost? I remember seeing that the turbo Olds V8s had the "Turbo Rocket Fluid" which was just factory meth injection. I wonder if the Turbo Corvairs had something similar.Basically they just strapped a heater on top of the motor and made the carb offset. Biggest turd ever but I always had lots of thumbs up while driving it.
Hmm, that’s Interesting. Slap some real fuel injection on it, get the turbo off the top of the intake, and run an intercooler. Then it might feel like it does something. Does make decent turbo noises tho.
Those aren't the original tires. They 'should' be BF Goodrich Radial T/A's.
In 1980 and 1981, premium gasoline was still leaded, so these had to run on 87 octane.
The 1980 without the computer still should have had a knock retard system. The 1981 would have an ECM. Both would have had a baud rate that was super slow. They would pull too much timing and hold it out for too long.
Best would be to run a non-ECM set up, jet the carb for E85 and then use this for knock protection:
J&S Electronics SafeGuard Indivdual Cylinder Knock Control
www.jandssafeguard.com
I hope to run this one day on my '82 Turbo Buick. The 301 Turbo set up was borrowed from Buick's Carb/Turbo draw thru system. I've run 15 psi on the Buick setup with race gas. The 301 T will make well more than 5 psi.
