checking rim trueness
g-rat2
New member
Dec 1, 2009
3
anybody out there capable of checking rims for trueness?!?!
had a nasty shake in my GTP @ 60 to 70 mph, took it back to NTB to check balance and here's what they told me " two rears were OK, two fronts were off 2.5 to 3 but both are bent. they balanced ok but the bends are what's causing the shake"
not sure if I trust these guys since they didn't mention anything until I asked!
would love to know if they really are bent before I invest in replacements and/or aftermarkets?
32,645
16,113
put car on jackstands, start engine put into reverse or 1st gear, look at rim flange, while tires are spinning, alternatly you can swap em to the rear and spin em by hand while looking.
they may have been bl9owing smoke up your ass or not but 2.5-3 oz is more than enough to cause a shake at 60-70
cheepo tires with sidewall belt overlap can cause a similar issue, look at the sidewalls if you see one spot where the sidewall looks straighter than the rest of it (a radial line as it were) this could also be the case.
  • G
  • 2
  • 341
