cheap daily
04 cvpi with 188,170 miles, kodiac brown, cloth buckets, rear bench, single disc aftermarket head unit. currently sitting on nitto tires with steel wheels, retrofit source HID conversion harness.
this thing will come with a ton of service history records. that said it overheated a little over a week ago, it’s not holding pressure and a radiator is assumed to need replacement. basically a weekends worth of work, and a few bucks in parts will have you in a cheap, running workhorse.
cosmetically the car is a 10 footer (the paint is checking), mild tear on the rear bumper. quirks; the hvac speed control needs attention but on high works and modulates temp fine (cold and hot are sufficient), rear window switch needs attention.
asking 750 obo car is parked in buffalo grove.
  • V
  • 1
  • 371
