Changing crank pulleys
Xtant12
So I plan to do the 8 rib crank in march/april. I was wondering if the people who have done it could give me some tips on how to do it, what I will need, ect. I was going to buy the tool but on ZZP there is these different options and the dam tool gets expensive. I will rent it from advanced or something. Looking at it I dont think it will be to hard but you never know. Anyone know if I did decide to buy it what option I would need to get from the zzp site??
Thanks guys..
frosty23_45
Broke Dodge owner
Coal City, IL
The puller you should be able to rent I would think. I don't know what the charges would be though.
02BlueGT
No Fucks Have Been Given
Now apearing in Hanover Park
I got the puller from ZZP, the main issue is the Bolts, the 3800 balancer uses a smaller than normal hole and thread, so the special bolts are needed......But, have fun with the crank bolt....200+ ft lbs FTL..... You can use the starter to break the bolt loose though, just make sure the car doesn't start
Runtz52
Manhattan
makin it not start is easy, just pull the relay for the fuel pump, and run it til it dies, then itll crank and not start
Xtant12
about how long do u guys think it will take???
ilikemtb999
I eat dirt
Denver, CO
I just rented a tool from autozone and bought the bolts I needed at ace. I also put a metal rod into the crank so I didn't fuck up the threads. It was like $5 total.
Also air tools ftw.
Xtant12
Also air tools ftw.
Thanks for the info. When it comes time to do it I will go to Auto-zone..
10sec
:nutz:
