put new ngk tr6 plugs gapped at .035 in now it starts but sounds like its running on 3 cyl and dies out wont idle anyone have any sug. thanks
+1 make sure yoour coil packs are snapped on the plugs as well.
And make sure all the harness to each coil is plugged in
improper gap should not throw codes... something is not connected correctly
you may have mixed up the connections for the coilpacks which to my knowledge would mess up the firing sequence
That is impossible to do.
100% impossible!
...im sure someone has done it somewhere:alcoholic
ok at 1:30am we fig. out 3 of the 4 coil paks on the driver side are not firing prop.1 not at all the other 2 intermit.so it looks like im going to replace all the paks any thoughts (stock ford) or GMS or Accel?Thanks guys (this is turning into the most expensive spark plug change in history)!
