Changes:You have changed things, you must reverse the changes until you figure out the problem. That is how you will fix your vehicle.
Relay is fine, primes at key ON, primes after start attempt.Have not read entire thread. So beat me up if you like. You try the fuel pump relay?
That's the plan for tonight/tomorrow morning. What did you ultimately determine from that?When I was checking for bad injectors, I pulled the fuel rail off with the injectors attached and cranked the engine. Yes it sprayed gasoline all over, but just a tiny amount and the engine was cold. It let me see which injectors were opening and which were not (and one kept leaking even when off).
BOO to stock injectors! I guess I have no choice tho. That plan works for me. I have no idea where my stockers went.I can go home, change, and grab a set of L67 injectors
Oh, I have no idea then. I would think/hope that's not bad. I THINK the sending unit was replaced probably 5 years ago when the Walbro 255 was installed during the swap project. I guess I have no way of knowing if that hose is bad without dropping the tank. The pump seemed to flow well enough when we were emptying the tank, but I suppose that could be a completely different story when it's trying to build pressure while pumping. Again tho, wouldn't I at least get some chugging and SOME firing, even if shitty?
You got a 1/8 NPT fuel pressure gauge lying around that I could borrow? The PRJ rails have no Schrader valve, so I'm looking to install a gauge right into the FPR adapter block.It would be dribbling fuel out the injectors if it was only seeing 0-10 psi. Ruptured pump hoses are fairly common. if you're not getting a large amount of fuel coming out of the regulator going towards the tank then no it is not building pressure it takes pressure to open the fuel pressure regulator and allow it to return to the tank so that gives you one thing you can test
Gotcha, that's kinda what I was alluding to. That'll be easier to check than pull up the entire rail too. Will be my next course of action.I was referring to removing the return line side off of the fuel pressure regulator....aka the 5/16ths side. ..past/downstream of the regulator.
A burst hose at low pressure will flow quite well since the break will not be forced open. when it tries to build pressure a split hose inside the tank would open wide up and not allow any fuel pressure to build.
yes I got one 1/8th npt
I see [MENTION=109]TommyGloves[/MENTION] lurking. Any recommendations?
I'm probably just going to take the line off of the FPR that goes to the rails to see what kind of pressure I'm getting out of it. Definitely appreciate the offer tho. I just need to find a 1/8 NPT Schrader valve, or a 1/8 NPT fuel pressure gauge to hook up to the PRJ FPR block.Red arrow in pic
Plugs are new
Installed while the engine was out? Or installed after the headers were bolted on and safe from damage
I'm telling you man... you know I'm totally right... it's that your car just has blue balls....
you fix that and it'll start right up
flashed with wrong MAF file? bad MAF?
I have a spare
