What do you suggest? I’ve pretty much been doing that for 25yrs and first time I ever had a ground issue. Also why did it go bad after a few months is my bigger concern?Omg that’s worse
The self tapper screw could have loosened over time now causing an issue. Last year the battery terminal was slightly loose and my radio would randomly restart. No other issues including starting.What do you suggest? I’ve pretty much been doing that for 25yrs and first time I ever had a ground issue. Also why did it go bad after a few months is my bigger concern?
No it’s not like the pic posted lol
Checked the self tapper, thats was the first thing I checked when I checked the ground today. Its as tight as it was when it was installed.The self tapper screw could have loosened over time now causing an issue. Last year the battery terminal was slightly loose and my radio would randomly restart. No other issues including starting.
Obviously clean metal as you know. I’d recommend a solid bolt solution through multiple layers of steel vs a screw.
Still do them when I run a big enough system. Didnt think it was necessary on my Hoe.I’m having flashbacks to “big 3” upgrades from the 3800 days. I know I replaced 3 cables under the hood with 4ga.
I'll check tomorrow and report back, where are you going with the ground position?Does the main battery ground go to the frame of the truck or the unibody?
I have enough 4 gauge laying around to run it outside the car to the battery to give that a shot.if youve got the wire, just try running direct and make sure it fixes your problem
You bump a wire or arc somethin? You running caps?I'm going to go out and do some more trouble shooting today and will start at the ground.
Also as mentioned, everything was working 100% fine up until I made the switch to the 1200/1 amp. Probably has nothing to do with it, but its strange
Brand new truck, so assuming its grounded to the body, arent they all? (not being sarcastic)
Sub signal, meaning my RCA's, if so. I'm grabbing that from the front door speakers using below link
Auto turn on, no. I was always under the impression that only came with some LOC which I'm not using
JL Audio XD-CLRAIC2-SW | 2-channel Speaker Wire to RCA Adaptor
JL Audio XD-CLRAIC2-SW Speaker Wire to RCA Cable • 2-channel Speaker Wire to RCA Adaptor for High-Level Signal Connection to Amplifiers 2-Channel Speaker Wire to RCA Adaptor for High-Level Signal Connection to Amplifiers • Left and Right Channel Male RCA Plugs to Parallel Speaker Cable • Satin...www.sonicelectronix.com
No and no.You bump a wire or arc somethin? You running caps?
Thats in my 17 ltz I hid a shallow mount skar 12 800 watt amp and 2 farad cap underneath the back seat. Had to get that pac adapter to hook it in with the bose but I've been slammin systems in stuff since I was 14. Got 2 10s in the camaro in the side boxes so I can still put my t tops back there got a 10 in my boom truck got a whole ass other 12 1000 watt amp and wires sittin here for some other reason too. I pretty much won't drive anything with a shitty stereo but id rock an 81 Honda if it had some decent beats in it lolNo and no.
What are you running in your vehicle?
I started installing at 18, and I'm 45 now. Thats the way I was taught and thats how I have always done it.I thought all this stuff was common knowledge? But I forget I dropped out of college for electronics alot [emoji23]
