I used to have it mounted right under the rearview mirror but now it's lower and just above the dash. Less obstruction and works just as well.my radar detector is mounted under my rearview mirror, but no obstruction of view.
I was pulled over probably 10 times for tinted windows on my old car, never once did a cop say anything other than a snide remark that radar detectors dont work
Generally, that is not a primary offense, meaning, you can’t be stopped for it solely. That doesn’t mean someone won’t be over zealous and do it anyhow. I’ve been stopped for stupid crap, getting upset won’t help, knowing the law will for sure.
This is wrong.
Depending on the size of the object yes you can be pulled over for it solely. It’s called probable cause to stop. And can also be solely cited for it.
Case law shows the air freshener trees are not “large” enough to obstruct view, so take that for what it’s worth. If you have a larger item hanging, you might be at risk. smaller then you should be good.
You are allowed to however have mounted GPS/phone folders between you and the windshield. Radars fall Into to that category also typically.
Not sure what is “wrong”, I’m in Ohio, it’s a secondary offense, your state’s laws will probably vary.
Just like we can’t stop someone for texting and driving, unless there is another primary offense, likely, your state laws will vary.
Ah ok I assumed you were in Illinois.
This is wrong.
