With weight makes the most sense.
THIS!! I think there is some sort of rating related to the square footage of the face of the trailer. You don’t ever hear anyone talk about it though.
of course now i can't find it
i should have worded that better.
like if you're pulling a barn but it only weighs 700lbs, the aero takes a fuck ton more into account than the weight. and weight is negligible
not that it doesn't count.
Example for me is when I grabbed my trailer from Carbondale. I left the canopy on, HUGE mistake because it really didn't weigh that much but truck worked so hard to pull it because it was like a fucking barn....
Data plate says 1,340 lbs
If you are going to leave the camper at a permanent site just send it with your current truck. I tow alot with my 240K 04 Tahoe and also worry about how much longer the trans would last but the cost to "upgrade" to something newer with even the same towing capacity is absolutely insane now days.
might be fun to find a truck with a brake setup and big enough hitch to tow something this size.
probably have to go through a commercial truck rental setup.
* Trailer hitch available only if renting towable equipment from The Home Depot; applies to 2015 and newer model year F250s
.* Trailer hitch available only if renting towable equipment from The Home Depot; applies to 2015 and newer model year F250s
so when i worked at the big E, the way to get something with a hitch (well hopefully) was to say that you needed to put a hitch mounted bike rack on it- and some places would help you out to secure that
otherwise most of E's stuff doesn't have hitches
the 3 rental pickemups i had last year didn't have shit.
.*The Total Estimated Charge includes 300 miles free for the selected rental period, and you will be charged $ 0.25 USD for each additional mile. Additional surcharges and taxes may apply. An additional charge for towing may apply. Contact rental branch for more details.
I want to figure out my frontal sq ft.well.
kinda. but granted, this is ancient... from the 2002 ford towing guide.
https://www.fleet.ford.com/resources/ford/general/pdf/towingguides/2002_All.pdf
But the specific aerodynamics of the truck would negate at least some of the front area of the trailer. For instance, an open bed would create a different aerodynamic profile as one with a hard tonneau, as one with a cap
