So one of the things I recently discovered is that the L36 and L67 have different cam timings. Doing some googling I found that most people will say the L67 has about 2 degrees advance over the L36.
I had to do some research to figure out what the benefits of that are, but if that were true then the L67 would have had a peak power about 100 rpm sooner than the L36. Not a big deal but I wanted to see it for myself.
I found from cross-referencing parts on rockauto that the difference in timing comes from the cam sprocket since the crank sprocket is the same part number between the two.
Checking my own sets of timing chains from my motors in my garage I found though that the L67 having 2 degrees of advance is pretty incorrect.
Here is the L67 sprocket laid on top of the L36 sprocket with the keyways lined up.
You can see that the cam sensor is a bit further counter-clockwise on the L67 cam proving that the L67 cam is actually retarded compared to the L36.
Here are the timing marks between the two.
So the L67 cam is half a tooth retarded, and on a 48 tooth gear this would roughly 4 degrees of difference there. So the L67 should in theory have about a 200 rpm later power peak according to what would be expected from retarding the cam.
Based on what I've been able to find online and on an episode of engine masters, it seems like retarded cam timing will even make more power across most of the rpm range as well, but I doubt anyone has tested this too much on a 3800.
Not a big deal if you're already running a rollmaster since you can adjust the cam timing, but I still thought this was pretty cool information.
