Been doing a lot of research with all of the cams available and still having a hard time deciding on what I want. Changing rods, springs, retainers is not an issue so I would like some opinions. Go.
Idle doesn't make the car faster... This isn't CGP
Xp or S1X, i love both, 51% s1x 49% xp.
I run the xp of course, figures, but i would recommend either, they're awesome cams. My xp with a couple other changes is a huge step between rockers, not fun under 50mph due to traction issues, it's FWD can't complain. I personally would run 130's with a double roller on the xp due to it's low valve to piston clearance (per PRJ's suggestions ) which is what i run. Makes for a reliable setup IMO, also rules out ever having valve float. My idle sounds stock so no video to post with that. I have a 30-almost-80 vid...
http://www.youtube.com/watch?v=ia8P2R285Cw
un-tuned at the time of video, it's slow but could probably beat some single cam civics
I am assuming that is the XP hot cam. That sounds really good and the power gains are pretty good on stock heads from what I hear. Are you running an I/C with that setup or just the cam? What else did you have to do with that setup? 105# springs?
Cams are cool, I want one too.
All I got is stock junk with a broken plug wire, the idle sounds kind of cool sometimes.
Slow my ass, are you running the XPZ or XP Hot cam on your setup? Did you need to machine the guides when installing either one of these?
