C6 - Cold air blows out driver side, Ac blows out Pass Side while Heat On....?
HeavyG
5,903
3,747
Any one encounter this?
Climate control adjusted from 60 to 90. Driver side is blowing cold while heat coming out passanger side....
I dont believe it's the actuator door as when I turn on the heat I can hear the ac compressor click on.
I believe it's the climate control button panel.
Maybe all those years of coffee lightly touching the buttons shortned it out?
Thanks
Gone_2022
13,094
7,525
Thanks for the input..... would you be able to explain why the ac compressor still turns on after the temperature is raised up to 90 degrees? Thanks
The a/c may be turned on or if defrost is selected at all the a/c is automatically engaged to reduce humidity. If one side is set to 60 and the other 90 the AC may run as well when u set it down to a certain temp.
I agree as stated above potential sticking actuator. That's the number 1 cause in normal cases.
  • HeavyG
  • 5
  • 582
