Yes. But when I went slicks I shaved off .4 tenths on IRS so in the end it's all the same shit. Just one makes life a little easier at the track.
Yes 36 mm socket is a must. Level 5s are a waste IMO.
13-15psi track
20-22street
close the thread
20-22 psi on the street that isnt too low ?
i droped the car off at deans im prolly going to add some H and R springs soon
springs and shocks and struts are stock on the car
Practice Pussy....:lmao:
Race springs and get a pair of GT wheels with a MT 10.5 and run like 5 psi at the track. Until you try that I wouldn't do anything else
I have just over 600 hp stock rear other than IRS brace and 28" slicks. so far 1.608 60ft. my first time with the new setup. waiting to see what I can really get out of it htis year
:deadhorse:
:deadhorse::deadhorse:
:deadhorse::deadhorse::deadhorse:
:deadhorse::deadhorse::deadhorse::deadhorse:
Exactly. A solid axle isn't a magical cure that will provide traction. If you can't hook on a decent tire with an IRS, there are likely other reasons.
If you expect a solid axle is going to give you a full second of ET you're going to be massively disappointed.
Put a REAL tire on the car. Until you do that, you're not going anywhere.
Larry is the man.
let me drive it at the track, then you drive it... we compare notes
^seeI have just over 600 hp stock rear other than IRS brace and 28" slicks. so far 1.608 60ft. my first time with the new setup. waiting to see what I can really get out of it htis year
more parts won't fix your problemgoing to try those springs you were telling me about hopefully it helps fix my wheel hoping problem :headbang:
kudoslet me drive it at the track, then you drive it... we compare notes
unless you use your magic wand car is still going to wheel hop
^see
kudos
It's about practice and driving skill, victor has both
my car will wheel hop no matter who drives it something is wrong with the IRS
Nothing is wrong with the IRS, they all hop, it's how it is...especially on a 17" tire. You have to slip the clutch a little bit and put a slick on it. People race on them all the time. I'll bet any money with a slick and vic driving he picks up .4 in the 60 and doesn't hop one bit without adding any parts.
i dont wheelhop and all i have done is mt et streets and h&r race springs... for now
