I'm trying to not use facebook, because...facebook, so maybe you guys can help out.
I swapped this 1993 Yukon circa 2017 with a 5.3 4l60e. Enjoyed it for a little while and decided to try the sloppy recipe incrementally. I cam'd it (ss2), and put a turbo on with low boost and enjoyed for a bit. Turned it up to about 14psi and hadn't learned about soft timing before peak torque and blew it up. Spun a nice ole rod bearing.
I bought a junkyard 5.3, put my cam in it and left the turbo off. This engine smoked like all the time, and had bad lifter clatter. I drove that one for about a year and about 2 months ago someone offered me a gen 3.5 5.3 for free. Said it had lifter tick and oil leaks and the customer decided to just replace it. I pulled the heads, cleaned the carbon off the pistons, put some LS7 lifters and MLS headgaskets and slapped it back together. Even with new lifters, and the same SS2 cam from my first build it has terrible lifter clatter, and smokes like a chimney also.
I am halfway inclined to do valve stem seals to see if it remedies the smoking, but I haven't a clue what to do about the rowdy lifter noise. You guys have any ideas? Measure pushrods? What is the actual stock length?
Positive note, I used the summit 3k stall converter on a fresh 4l60 and the damn thing flies. It's a whole new animal with the cam and converter.
