Buick won't start help please
DynaSlim
Plainfield
03 Buick century 3.1L I think.
New battery and tested it good.
When it does run good voltage from alternator 15ish.
Bridged the connection on the starter and it spins freely.
When it started getting cold like below 32 it would fail to turn the starter. Key in full power to everything but once turned to in gage the starter all power cuts out.
I'm thinking a sensor maybe? Any other suggestions please?
starter, ign switch, batt connections, power/ground cables, block/power connections
you bridged the starter solenoid and all it did was spin? prob the starter as the bendix didnt pop out probably cause of old thick grease/cold temps
but your last statement sounds like a bad connection...
DynaSlim
Plainfield
I was thinking/reading that the coolant sensor maybe is bad? I don't see how this would prevent the car from starting tho it has had low coolant light on the dash all summer but been full.
DynaSlim
Plainfield
Thanks. I'm going to freeze my ass off around 2 PM checking them. I know they didn't look corroded but I'll start checking.
Funny thing tho was I would bring the new battery in the house to warm up then it would start no problem but last time I tried that I got nothing.
Couple times I messed with the power connection like loosened it a bit and it would crank. But again I'm getting nothing this time around.
Harbor Master
sounds to me like ignition switch
b4black
Oswego
this:
STARTER SOLENOID BUICK CADILLAC CHEVROLET GMC PONTIAC
The power to most accessories cuts off when trying to start a car (normal). When the solenoid fails, the starter does nothing when the key is turned. On both my 3800's, the failure was intermittent. Car wouldn't start, turn the key again, started perfectly. Eventually it gave up completely. First time, I replace the complete starter for $150. Next time, I just replaced this. Local auto pats store did not carry just the solenoid. (Also check ebay)
DynaSlim
Plainfield
It does have the chip in the key. One time I messed with the key flipping it on/off couple times really fast and it decided to crank but that's not working this time around.
Harbor Master
Ignition switch. This all sounds the exact same as what I dealt with with my mom's car. They are way cheaper on Amazon than at the parts store too fyi
Mike K
Forum Sponsor
Sounds like a loose ground to me. This used to happen all the time in my old Taurus. I'd start it, lose power to everything and would need to wiggle the ground cable on the battery to get it to come back.
DynaSlim
Plainfield
Your Regal won't start cause your ignition system is getting wet. Cracked coil maybe? Used to happen to my astro until I sealed up the distributor really good.
Didn't notice it wasa link oops
Jean Ralphio
beautiful, clean coal
isnt this guy supposed to be on global ignore?
DynaSlim
Plainfield
I'm just going to replace this battery it's under warranty and doesn't seem to hold charge in the cold. I had it on battery tender all night which also fully charged it and then the car fired up no problem.
RICH17
Dr. Pussy Slayer, MD
The 007
Tenders dont usually charge batteries. They're a maintainer
