Yes. Which I figure loaded up I'm 4k and tow vehicle is 5200ishif what you are towing is at least 50% of tow vehicle weight? is that what you are saying?
I gotta think my lighter rv probably tows harsher than your boat given the aerodynamics alone. So maybe there isn't a different rule of thumb for boats and open trailers???I mean basically anything over 4k trailer weight would need a wd hitch by that description then though.
My boat's a good amount heavier than my truck on the trailer.
Me too, I was just making a joke. it probably would be beneficial to have one
bub lemme borrow your fancy hitchamawhatchit
owners manual says send it.
I just can't picture my trailer having more than 1500lbs of tongue weight or so... and i've had 4k ish in my bed before and it's been a comfy ride.
I think i'd try one out before spending the coin and buying one.
Next $250-300 trailering purchase will be an adjustable ball mount.
Just be warned it's got all the ugga duggas
10% of your trailering weight should be your tongue weight? Is ur boat 15k??
When Is Weight Distribution Needed?
You would likely benefit from a weight distribution system if:
Your trailer weight (GTW) is more than 50 percent of your vehicle's weight (GVWR) yes
The rear of your tow vehicle sags when the trailer is hooked up nope
You experience trailer sway nope
Your tow vehicle's headlights point upward nope
You find it difficult to steer or stop your rig nope
You want to tow to the highest capacity allowed by your vehicle's trailer hitch nope
This is funny cuz he owns campingworldyeah... have to remove bars when backing or making tight turns.
Bigger thanks to V8 pah
