Adding leafs to the packPlans for the rear springs? Air bags?
+1One helper leaf is all that's needed. The half inch shouldn't be too noticed
I suggest a 1 ton chevy to pull it or a 2.7 ecoboost ford which ever works....
If you’re going Ferd, just get the ‘Yote F150. Nobody wants them and you can get a hell of a deal on them. Plus it probably will get better gas mileage while towing than the EgoBoosts
Oh and the ‘Yote doesn’t sound like wet diarrhea
My headlights were a little high driving last night for the first time i was regularly getting flashed. (High beams Emerballs not tiddies) for $50 for the zone add a leaf I'll give it a shot. GM doesn't recommend a WD hitch in this thing until 5,000+ lbs because of stabilatrek Trailer sway control apparently.It only weighs 4,000 lbs. I'm sure you're fine without adding an extra leaf or airbags. Just get a load leveling hitch so you don't sacrifice ride quality when you're not towing.
Thanks for the clarification...My headlights were a little high driving last night for the first time i was regularly getting flashed. (High beams Emerballs not tiddies) for $50 for the zone add a leaf I'll give it a shot. GM doesn't recommend a WD hitch in this thing until 5,000+ lbs because of stabilatrek Trailer sway control apparently.
Like a bauce
Maybe I'll do a bag on the driver's side and a leaf on the passenger side see which side performs betterI’d still do bags over an add a leaf. Even for the price.
Like a bauce
All 4 seem to be in a different spot. Only one of which lines up. I can't imagine it being a big deal. Maybe I'll take em up the street and have them check balance. I ordered them already mountedShouldn't the valve stem be by the yellow dot?
