Bub's "When this things a Rockin' we are in there doin it v.6
Bub
Pitter Patter
Pistakee Highlands
2002 Aero Cub C215
Dry weight: 2888 (weighed in at 3180lbs when I hit the scales last night)
GVWR: 4980
Floors are solid on this thing with newer vinyl planking. Everything works and the fridge also can run off propane so I can keep 6 packs of be err soda cold while in tow.
Plans are to convert to LED lighting, maybe look into a solar set up since it already has wiring for a deep cycle battery and whatever else comes our way. Also would like a screen room on the awning
Now...
The Story:
Drove home last night from Germantown,Wi. and the truck seemed to struggle a bit not bad but we drove home around 2,000rpm and a little more. The trailer is also swaying bad. I am in full panic mode because I can't figure out how a 1/2 ton with 7100lbs tow capacity is struggling with 3000lbs. I am now questioning everything. We get home after burning close to a half than of e85 getting shit mileage and white knuckling the whole way and I stop at my parents and get out only to immediately realize what I had done. . .
When I hooked up the trailer the stabilizer jacks we're still out and I didn't even think of checking the tires once the weight was back on it. One tire was as low as 8psi and the others weren't much better. So add that to the I didn't bother buying a brake controller yet nor did I use a WD hitch list and I think I found my problem. I inflated to 40psi (tire sidewall calls for 50psi cold) and drove the last few miles home getting between 12-13mpgs on e85 through the hills on wilmot road and I didn't feel the trailer other than braking.
TCG: We know towing.
So attached are a few shit pics. I'll log mods, maint and trips in this thread and hopefully with this luckily happy ending potentially terrible experience it will serve us many years
And @emerballs and @kj I sat in this thing half the night last night drinking beer and checking for water leaks. It's good. 2018_1002_10533900.jpeg2018_1002_10540400.jpeg2018_1002_10551200.jpeg2018_1002_10553300.jpeg
EmersonHart13
Member Selfie
I can't wait to shit in that toilet while KJ schools you on towing with cold beer in our hands and the fridge.
10sec
So the pooping would happen to be taking place WHILE KJ is learning him on towing?
EmersonHart13
Member Selfie
Yes, if the shit ends up and stays in the toilet then Bub has learned to tow....
N20GT
Plz place 3,000 kudos here. kthx
Crown point, IN
How hot were those tires when you stopped? They probably all need to be replaced if you drove that far on <15 lbs.
Bub
Pitter Patter
Pistakee Highlands
The plan is replacement since I don't know the age of them and piece of mind
Harbor Master
good call on the leak check last night in the fuckin monsoon
:bigthumb:
OffshoreDrilling
This is my safe space
Chicago
Bad ass pick up. Love me some hilljack camper stuff. In for mods and camping adventures with the fam, congrats!
10sec
RICH17
Dr. Pussy Slayer, MD
The 007
Looks like a perfect one. Not a tiny pop up and not a giant one.
Bub
Pitter Patter
Pistakee Highlands
No DOT numbers on the sidewall? Looks like a clean camper. No leaks =
I gave it a quick look in the dark when I got home. I will look further today
That's what we wanted. Something comfy with a/c but would be manageable on the road
EmersonHart13
Member Selfie
I laughed at the b.s. attempt to wash it. Dude could barely get into the damn thing his back was fuuuuuuucccckkked. It needs a deep scrub.
When are you christening this thing???
Bub
Pitter Patter
Pistakee Highlands
I begged like a HS kid on prom night when we got home. Mrs. Bub wasn't having it. I fear it's going to be a dry winter in dis bish
EmersonHart13
Member Selfie
I knew you wouldn't say next year. My MAN!
