🔧 BUILD Broke EF turbo LS SC400 Build
I may have never posted on here before, but for some reason I am inspired to post my build up here. I am going to copy and paste from another site to get us all up to speed. I will try and clean up anything that was specific to the thread I am pulling from. Now that I am getting started on the main fab work I will update this thread in real time.
For anyone who doesn't want to read it all here is the short version. I bought the car on a whim in June of 2016. It is a 1993 SC400 that was from this area, and was meticulously maintained at the dealer. I was going to stay with the original 1UZ so you will see I started installing a procharger on it. I ended up selling off the stock motor, trans, ecu and harness to a local guy and got an iron gen 3 5.3 motor. I am doing a Precision LS-7675 turbo with a truck manifold based kit (more or less). It will be backed up by a TH400, and for now will use a stock ECU with HP Tuners.
Alright, time for the massive dump of info.
A couple years ago I picked up a 1993 SC400. I wasn't really looking for a car, but a late night search found this one, and I have always liked them. I decided to go down and give it a look in person, and it was even cleaner than it looked in the pics so I bought it. Here are a couple pics of when I first got it.
I wont bore you with all of the middle shit, just hit you with the highlights.
I removed a couple tons of wiring that used to be an alarm system.
I had the gauge cluster fixed/updated with white LED's.
Fixed up the wiring that was kind of hacked up from the alarm. Changed the steering wheel, etc. etc.
I then updated the climate control, and put in a nice head unit.
Just a bunch of little changes and fixing up small things here and there. The car was extremely well maintained and really did not NEED much. My plan was always to make it fast of course, and do drag week with it. The factory 1UZ motor is a very good starting point and can make some really solid HP. The stock trans can be built to live as well. Packaging was kind of a nightmare as you can see, but other than that it was a good option.
I ended up stumbling upon a great deal on a procharger kit that was actually on an SC400 locally. It was a P1SC that came with some shitty piping, a way too small intercooler, but a Tial blow off valve that actually had the right spring it it! I started installing that setup.
You can see one of the things that was constantly in the back of my mind for making this a drag week car. Look how complicated that engine looks! If I had a problem on the road not only would parts be an issue, but just the time to do simple repairs is a nightmare. For example the starter is under the intake manifold in the valley.
So when a local kid hurt the motor in his SC I offered mine up to get him back on the road since that is his only car. We struck a deal and I ripped that shit out the next day.
It happened to work out that a 5.3 LS came up for sale for the same money I just sold my old motor for, so I jumped on it.
Its update time! Nothing really exciting, but I have been slowly chipping away at things.
First up was wiring. I am planning on using the stock ECU for a little bit with HP Tuners, so I had some wiring work to do.
Harness as I got it with the motor
Stripped of all of the brittle loom and crappy electrical tape.
Unfortunately I ended up having to move it around after I had stripped off all of the crap, and it got pretty tangled.
So I decided to just fully depin everything since I only need a few things from that mess.
Here is the pile of junk I didn't need from that harness. There is actually a bit more, but that is 99.99% of it.
And here is everything all apart, ready to be cleaned, routed, extended, and loomed.
Next up I got some mounts for the LS from Dan Perlenfein. He even made me a custom trans mount for the TH400. These are very nice pieces, and I got them really quickly.
Got them set in the car, fit like a glove! (BTW they are not bolted down in any of these pics, just have the nut on the other side a few turns)
Next up I pulled the oil pan off my motor so I could drop it in and see what I am working with.
Bit of wishful thinking seeing of the truck intake would clear the hood. It wont.
So keep in mind that the mounts are not 100% bolted down yet. I need to get my trans from my buddy so I can get that in place before locking everything in place (just to take it all back out again). Once I have put the trans in then I can check a few things, and it can all come back out. Engine bay is going to get cleaned up, and the motor will get some TLC as well. I am still planning on trying to get it running and driving this year, but we will see if it happens. I am not one to let things be "good enough" so I may end up spending a bunch of money and time on the motor even though it will remain a stock bottom end.
Anyway I am really happy with the fitment, and how much space I have! This seems to be more room than I remember in an F-body (on the sides) even with a tubular K-Member. Should be able to get a big single in there no problem with a 4" down pipe to run out back. I am really glad I went LS!
Well time for a small update on the thread that nobody follows :) I got the trans, and a converter from my buddy a while back. Turns out the trans was shot, and needs a rebuild. That pretty much killed my plans for just getting it running this year. The good news is that I will be able to use it as a core to verify the trans mount, and hold everything in place so I can do all the fab work and wiring. I need to get un-lazy and move the car over in the garage so I can get the trans in one of these days. Its been hot as balls, and until I got my turbo there hasn't been much of a reason to bother getting it done. That excuse is out the window now though, since this came in last week
Its nothing special, just a Precision LS 7675, which is a cast wheel journal bearing 76mm. It should be able to max out the 5.3 though, so it will do for now. This weekend (it was hot as balls) I went out to the garage for a bit to try and get some idea where I was going to place the turbo so I can start getting an idea for a materials list. First up I got the radiator sitting in place (close enough)
These were the most obvious positions (turbo would need to be clocked differently for most) that I snapped some pics of not in any particular order.
Inside forward facing 45
TA style
Outside forward facing
That is really about all I got right now. I guess I also got the LS6 intake since my last update. That is still sitting on the truck steam ports which is why it isn't flat. I also got a set of non-EGR truck manifolds to use as the base of the turbo kit.
So right now I need to get everything mounted temporarily. That includes the trans, front accessories, exhaust manifolds, intake manifold, etc. Then I can lock down the turbo placement 100% and order material to start work. I also need to delete the ABS so I can mount the ECU over there and get started on the wiring. Well that's all for now, thanks for following along the journey of me seeing how dirty I can get my car.
Time for a small update, just because why not :)
I needed to get the trans in so I could check the fitment of the mount, as well as get everything locked into position for fabricating. Doing a trans by yourself is no fun, worse when you don't have a lift, and worse yet when you have to do some modifications for it to even fit. I ended up grabbing a trans jack from Harbor Freight to make my life a million times easier.
The only downside to it is that it is quite a bit taller than having the trans on my regular jack, but other than that it was SO MUCH BETTER. I could slowly move it into position and make small changes to angle and overall position with ease. Not to mention how nice it is to have the trans stable as you are moving around to get a good look at everything. It turns out it only needed a little massaging to get it bolted into place. Again, that is without a shield on it (or a bell) but I was glad I didn't have to spend hours hammering overhead.
Ignore the mess, the garage is in process of getting a lot of work as well.
Next up I wanted to see what I was working with on the exhaust manifolds.
Driver side is actually hitting the frame, but that is fine since I always planned on v-banding them anyway.
Plenty of space on the passenger side
Next up was trying to get an idea of what to do for accessories. There are about a million options out there these days. I started by trying to place the stock truck pieces just to get some idea.
Clearly those weren't going to work, but it was worth a shot. I have since figured out what I am going to do, but I will post more about that when I get all the parts. After that I reassembled the main fuse box under the hood. I need to patch where I cut for the procharger bracket, but the car is going to be outside for a bit while we finish the garage so I wanted to close off the fuses and wiring.
That was about it. Got the car back on the ground and pushed back out of the way for now.
Not really a crazy update, but progress none the less. While we are finishing the garage I will get the rest of the parts needed for the accessory drive setup. Once that is all in place I can start on fab work (FINALLY!), so hopefully the garage wont take too long. That's all I got for now, thanks for following along!
Nothing exciting, but parts have been coming in lately. I had to figure out and order up all of the front accessory drive components. Luckily there are a LOT of options for that kind of stuff these days. I ended up with a set of ICT billet brackets that will use a mix of F-body and Truck pieces.
While I am at it, I got all new everything else too since most of it required f-body pieces anyway.
New tensioner
New power steering pump pulley
I have a new water pump, but no pic of it. The new power steering pump will be here early next week as well. I haven't ordered an alternator yet, but I will later when I get a crank pulley.
Next up is some of the fabrication pieces for the turbo kit. I have only ordered the parts and pieces for the hot side so far.
All stainless steel T4 flange, four 2.5" 90's for the crossover, and a 4" 90 for the start of the down pipe
The stainless steel adapter from the weird 3-5/8" outlet of the turbo to 4" tubing.
I am still waiting on the 2.5" stainless v-band assemblies and the stainless O2 bung. I will also run another section of stainless on the downpipe, then a bellows, then adapt to aluminum for the rest of the exhaust. I probably wont start on that until after I do the cold side piping, which I will hopefully be able to start directly after the hot side fabrication is done. My garage is currently being finished, so I wont be able to start work for a couple weeks still, but its great to see parts coming in! That's all I got for now, thanks for following along.
Here are the 2.5" stainless steel v-band assemblies and the stainless steel O2 bung.
They are very nice with indexed flanges built in
Quick release clamps, another nice touch!
GM reman power steering pump came the other day as well
I was a bit surprised to see that the pump did not come with the pulley bolt, or the reservoir cap. Not a big deal, just slightly annoying. That is all I have for now. The garage is taking longer than expected, but I have also been working on the wife's car anyway. Sometime next week I will probably stock up on welding supplies so I can be ready to go. I should have enough to get started, but I know I will need some soon.
On to a bit of news, my garage is 90% done!! Paint went on last night, so now I can trim it this weekend and move everything back. Here are a couple quick pics.
For reference, here is a pic of the garage when we did our inspection (before we bought the house)
It had a single light bulb, and the opener was plugged into an outlet next to the switch with an extension cord duct taped to the drywall.
Here is a shot after we had added the sub panel, lights, and pulled down the drywall. I then insulated everything, and put up new 5/8" drywall.
I know not car related, but it has been a massive project that has delayed the car so I figured I would throw it in there now that I can see light at the end of that tunnel. Next update will be all car!
Well nothing too exciting to report still. I have been busy as hell finishing the garage, and getting our house ready for a party this weekend. I did however order up a bunch more material and pieces. I should have everything to build the intercooler piping except the intercooler (which is on backorder). I have all of the material to build my exhaust, but will probably need a couple v-bands so I can section it. Anyway, here are a couple pics.
Half stainless, half aluminum 4" V-band. I have two stainless steel 90's to come out of the turbo and get me to about the firewall, then it will be aluminum from there to the bumper. The other three pieces are 3" aluminum clamshell clamps for the intercooler piping.
Detail of the 4" v-band
And one of the clamshell clamps pulled apart.
I also got two boxes of piping as well. Those have a single stainless steel 4" 90, ten 3" aluminum 90's, six 4" aluminum 90's, two 4" aluminum 45's, two 2' long aluminum straight sections, a 3" silicone coupler, and a 3" to 3.5" silicone adapter with T-Bolt clamps. I am really hoping to start fabrication next weekend now that I should be done with all of these other projects. My pile of parts/material is starting to take up too much space!
Finally time for a bit of an update! After busting our asses on Friday night, the garage is now 99% done. All that really means for non OCD people is that I have more than 2 outlets (a LOT more) and don't need to drag extension cords all over! Let me back up a second, I needed to get the steering rack out of the car since it was wore out and I got a replacement for it. I also wanted to take the motor out to make taking the rack out easier, and so I could do some things with it on the stand. Thursday night I got under the car and pulled the trans.
Pretty easy to do with nothing really connected at all. Friday the car and the bike went outside while my buddy and I did the massive amount of electrical work in the garage. Saturday got mostly eaten up cleaning the garage from the previous nights thrashing. In the evening I got the car pulled back into the garage and was able to get back to work on it.
I let the snow melt off and dry up a bit before getting to work pulling the motor. Not terribly hard (again, nothing to disconnect or move), but kind of a pain in the ass since I have to come at it from the side.
So one of the first things I wanted to try, was see about fitting AC. I don't think I would run it this year, but if I could build with it in mind it would make things easy down the road. I grabbed a bracket and a junk compressor from a buddy so I could mock it up. He also had this manifold laying around, so I took that as well.
It is clearly a tight fit, but I think I could make it work. It pretty much kills running a 4" downpipe on the passenger side though, so I grabbed a piece of tubing to see what it looked like on the driver side.
Again, very tight but I should be able to make that work if I need to. I still haven't decided if I am going to mess with it or not, but its good to know about options. Next up was getting the front accessory drive all installed.
All laid out on the bench (minus the water pump since I forgot where I put it!)
Unfortunately I have the wrong tensioner, and I clearly still need parts (balancer, thermostat housing, alternator, etc.) but I can move forward with fabrication for now. Once that was done I pulled out the old rack.
Then I got the new poly bushing installed in the new rack
Then got it put in for now.
I am going to change the "EVO component", intermediate shaft, and outer tierods but its in the car so I can fabricate around it for now and keep it out of my way.
Then I got busy organizing all of my material so I could clear the space under my bench.
Pile of tubing!
Ahhhh thats better
At that point I was going to call it a night, but I decided to dive in and try and get something done. So I busted out the big boy grinder
Then I hacked off the end of the driver side manifold
Unfortunately, that was where I had to end it. Its been so long since I have welded, the batteries in the hood were dead! I am going to stop and get some on my way home today, and I am also waiting on some welding supplies. It was great to FINALLY be working on the car again! Like I said I am still unsure on the whole AC deal, but I think for now I am going to cut up that manifold and see whats up. I will also be putting the motor back in the car as soon as I get my new steering parts (that is a whole story on its own). Thats all I have for now, thanks as always for following along!
WHEW, that was a lot of info! I ended up having to pull the post from a site I had already done this same thing on. So I again apologize if it doesn't make a ton of sense since it was a catch up on a catch up. Going forward this will get updated in real time though. I have some tools and supplies coming this Friday, so hopefully I can get a good jump on some of the fab work. I guess we will see how it goes. Look for an update later in the weekend, or Monday. Hope you guys enjoy the build, I look forward to hearing from you guys.
Thanks,
Sean
Broke EF
1,785
4,551
The sticks
Well just a quick lil update. I ended up ordering a chromolly cage kit on Friday. I went back and forth on what to do, prebent, build, or have one done. With material prices where they are it was kind of a no brainer. The prebent kit was less than half of my cost for material (through work even), and that was with shipping. Fingers crossed its not a total pile of shit, but I know I have some wiggle in the fitment so it should be OK.
Sunday I swapped the SC and the Supra back. I had the Supra over by a neighbor just cause I have no room.
Got the SC warmed up
And then let the neighbor drive it over to his house.
Then the wife and I spent all day working on cleaning up the garage. It still needs a lot, but its much better than it was.
I want to get the Supra done so I can get some other projects going, so that is next on the list. I need to work on figuring out my exact plans for the SC, but I know the basics already. I know I want to get the boost conrtoller done, trans brake, exhaust and a few other things. I need to make a list of parts to buy so I can start getting them knocked out too.
Well thats all for now. You should probably start seeing more Supra content soon :)
Broke EF
1,785
4,551
The sticks
What still needs to be done on the supra?
Everything [emoji1787][emoji23]. I was waiting on parts from him, which he has now just needs to drop off. I need to finish the trans crossmember then start on the fuel system, wiring, etc.
My cage is apparently already at the house! That was fast as hell!!
Reactions: Jon01 and IDAFC21
24,637
In my experience, UPS is far worse at the "label has been created" than fed ex. Tho fed ex did just recently send one of my customers packages from Phoenix......where they are located.......to like fucking Kansas or some place, for no reason at all. I'm still waiting for that one to make its way back to Phoenix after its detour.
Broke EF
1,785
4,551
The sticks
Yeah, they all suck lately. I have had horrible luck with FedEx lately, but the last package is on its way now! Says it should be here tomorrow.
Are you short a bar?
Yes, I am missing a few. For sure I am missing the rear down bars (or door bars), kickers, harness bar, and probably a dash bar. Its not required, but I think the kit comes with one. It should also come with the floor plates. So we will see what shows up tomorrow :)
Reactions: IDAFC21
Broke EF
1,785
4,551
The sticks
You thinking of hitting the track one more time or are you done for the year?
I wasn't, but maybe.....
The last of the cage came in yesterday!
Less than 1 week to get it to my door. Not bad at all! I really want to start installing it, but I want to finish the Supra so the next project can come in :D
Broke EF
1,785
4,551
The sticks
Quick little update time.
First up a shot of the cage all laid out
Pretty happy with the cage overall! A little slag at the cuts, but nothing too terrible.
I powdercoated some parts at work last week.
Ignore the finger prints, but that is a center console trim piece and two radiator cooling plates.
And last up, I fixed the busted wastegate the other day.
I got it squeezed back together
As usual, ignore the messy bench. It has a lot of parts for both cars all over it. But all clampled up and back purging.
I welded over everything with 308 filler. I think first time I used 309 rod which I hear may have been part of my issue.
There is a chance I will cut this off and redo it still, but I wanted it fixed just in case. I took it out Saturday and it was making a solid 13lbs the couple time I was able to glance down at the screen. It was a little tail happy on the radials when its 40 degrees :)
I have ordered up some parts for the car but I will update that when I get them installed. I have also started looking at what events and stuff I wanted to do with the car next year. I really need to be a lot faster to do most of the things I want to do, but in order for that to happen I need a lot more parts (suspension, wheels, tires, etc.). So we will see what I end up doing. I am sure I will drive it a LOT more, and run it a LOT more next year though. The main goal is still at least Drag Week, if not one or two more drag and drive events. I just really also want to drive to a track, race (and go rounds) and then drive it home. That may end up having to be the following year though.
Anyway, I am ramblin so time for bed!
Broke EF
1,785
4,551
The sticks
Stock piling more parts for the car, if I ever get any time to work on it again. Today the good stuff came in!!!
OH YEAH, Car stero stuff for the "race car" :D
Its nothing crazy, but should be pretty nice. If you didnt already know I have a Pioneer AVH-4200NEX headunit in the car
I also bought speaker adapters for the doors forever ago. The stock speakers in this car are a weird 4" deal with a big backer box. When I got the headunit I also got almost all of the ancilary stuff including front and rear cameras. Because I had the factory Nakamichi system, wiring the headunit was/is a pain in the ass. When it was still the stock motor it turned on and everything, but its never actually played anything through speakers. Now that I did the LS wherever I was getting power from is apparently not happy, or maybe its just off. Who knows, the point is I will be rewiring a solid constant, and ACC power to it and the screen above it. The main point is that I was always planning on putting a system in the car, and have been trying to get good stuff for it to boot.
The current plan is to run front door speakers off of the headunit. I went with 6.5" Infinity Kappa 63XF's which have a pretty high sensitvity and are 3ohm which should translate into speakers that can play pretty loud off the headunit.
The next part of this equasion is bass. I have had a 10" Infinity reference 1062W sub for a while. I don't remeber why I have it, I bought it and have never taken it out of the box LOL. I also have a box I made for something else that I believe will work. For some reason I rememer it being damn near perfect with the correct port, but I will model it to be sure. I may end up building a new box anyway just depends on how I layout the trunk. To power that sub is the Alpine MRV-M500 mono amp. I have actually owned at least two of these before and had them in diffent cars with differnt subs. Its always been a great little amp that has plenty of power for a single sub and its easy to mount in a lot of places. I should dig up some pics of my old Cobalt that had this same amp, and I think the same Infinity sub in a sealed fiberglass box that I never fully finished. That set up hit way harder than it should have, everyone thought it was at least a ported 12" :)
Anyway, pics of the amp
Not much to show on a small mono amp :) I also got the Alpine control knob to be able to adjust the amp for different music or situations.
Since I know someone will ask, the plan is to make the box and the amp a combined setup that will unplug and easily come out of the car. I got a few disconnects for the power wiring. It will alow me to unplug the whole deal without having a live wire flopping around, and I can then plug the charger into the remaining side to charge the battery too. Who knows, maybe I will 3D print a holder for the plug when the box is out and I am making a pass.
Well thats enough rambling about a really basic stereo. I am a bit excited for it if you cant tell. Just happy to be getting another piece of the puzzle :)
Broke EF
1,785
4,551
The sticks
Well with this first hit of nice weather I couldn't resist taking the car to work, so I did :)
She was a little cold this morning when I left
Of course, she fired right up and ran like a top! I am super impressed with the tune up in this car. Anyway, I hopped on 90 and cruised 70-80 the whole way to work with 0 issues. When I was at work I had a handful of people ask me about the car. I have driven it in a few times, but I guess word travled this time? So at lunch I took out the resident car guys. The one guy is younger, drives a WRX, and was actually in it last year. He was pretty pumped, was taking video the whole time and had a big smile on his face. The other guy is newer, and is older. He drives a modded jeep and a boxer, asked a few times who did all the work LOL. Anyway I was like you wanna go for a ride and he said yeah so I brought him to Jesus LOL. I gave it a bit at first, like 30% just into boost and he was like damn this thing moves!! Then we turned down a nice road and without warning I got on it and it just spun through first and second. That got a lot more reaction, he was pretty shocked. We drove around a bit and before getting back I hit it with all the beans, and it dead hooked. That was the come to Jesus moment where he grabbed for anything and everything and was looking for a brake pedal before I even hit second. I made sure to stay in it into 3rd just to assert my dominace :D I guess its just a bit faster than his boxer, who knew. When we got back he was going around telling everyone.
Once work was over, I got in and hit the highway to head home. I had a guy hanging out of a truck taking a video (while driving) on 90 LOL. I ended up getting off 90 and taking some back roads just to be a little easier on the ole girl. I have a new rearend for the car, but the one thats in there makes it turn a LOT of RPM when I am cruising. As it sits now, the car loves to cruise around 55-60 and is perfecty at home on back roads.
So all in all it was about 100 miles today. Made some people smile, made some people question thier life choices, and the car took the abuse perfectly. She does need some TLC, and it'll get it soon. As II have said I have some parts around for it, I need to do maintenance, and overall get it ready for the track rental on May 6th :D
Broke EF
1,785
4,551
The sticks
So cool Sean. Good coolant temps I take it?
Thanks! Temps were good. I want to probably add in some ducting when I get the front end back on. That is something I want to dial in as good as possible before DW. I also have the big boy fan to put in as well.
Most excellent! That has to be a great feeling taking those guys on a rip.
Oh yeah, its a blast! I wish I had a camera in the car for the one guy. He came in today was like I went home and changed my underwear LOL
Glad to see that you got some miles on her. That's fuckin awesome. I just wanna get my shit going and do that.
Thanks!! Its pretty great! The only negative is that I want to take it apart to do a bunch of stuff, but then I dont want to take it apart cause I want to just drive it all the time. You need to get your car done! What do you have left on it?
Reactions: Pro Stock John
