🔧 BUILD Broke EF turbo LS SC400 Build
I may have never posted on here before, but for some reason I am inspired to post my build up here. I am going to copy and paste from another site to get us all up to speed. I will try and clean up anything that was specific to the thread I am pulling from. Now that I am getting started on the main fab work I will update this thread in real time.
For anyone who doesn't want to read it all here is the short version. I bought the car on a whim in June of 2016. It is a 1993 SC400 that was from this area, and was meticulously maintained at the dealer. I was going to stay with the original 1UZ so you will see I started installing a procharger on it. I ended up selling off the stock motor, trans, ecu and harness to a local guy and got an iron gen 3 5.3 motor. I am doing a Precision LS-7675 turbo with a truck manifold based kit (more or less). It will be backed up by a TH400, and for now will use a stock ECU with HP Tuners.
Alright, time for the massive dump of info.
A couple years ago I picked up a 1993 SC400. I wasn't really looking for a car, but a late night search found this one, and I have always liked them. I decided to go down and give it a look in person, and it was even cleaner than it looked in the pics so I bought it. Here are a couple pics of when I first got it.
I wont bore you with all of the middle shit, just hit you with the highlights.
I removed a couple tons of wiring that used to be an alarm system.
I had the gauge cluster fixed/updated with white LED's.
Fixed up the wiring that was kind of hacked up from the alarm. Changed the steering wheel, etc. etc.
I then updated the climate control, and put in a nice head unit.
Just a bunch of little changes and fixing up small things here and there. The car was extremely well maintained and really did not NEED much. My plan was always to make it fast of course, and do drag week with it. The factory 1UZ motor is a very good starting point and can make some really solid HP. The stock trans can be built to live as well. Packaging was kind of a nightmare as you can see, but other than that it was a good option.
I ended up stumbling upon a great deal on a procharger kit that was actually on an SC400 locally. It was a P1SC that came with some shitty piping, a way too small intercooler, but a Tial blow off valve that actually had the right spring it it! I started installing that setup.
You can see one of the things that was constantly in the back of my mind for making this a drag week car. Look how complicated that engine looks! If I had a problem on the road not only would parts be an issue, but just the time to do simple repairs is a nightmare. For example the starter is under the intake manifold in the valley.
So when a local kid hurt the motor in his SC I offered mine up to get him back on the road since that is his only car. We struck a deal and I ripped that shit out the next day.
It happened to work out that a 5.3 LS came up for sale for the same money I just sold my old motor for, so I jumped on it.
Its update time! Nothing really exciting, but I have been slowly chipping away at things.
First up was wiring. I am planning on using the stock ECU for a little bit with HP Tuners, so I had some wiring work to do.
Harness as I got it with the motor
Stripped of all of the brittle loom and crappy electrical tape.
Unfortunately I ended up having to move it around after I had stripped off all of the crap, and it got pretty tangled.
So I decided to just fully depin everything since I only need a few things from that mess.
Here is the pile of junk I didn't need from that harness. There is actually a bit more, but that is 99.99% of it.
And here is everything all apart, ready to be cleaned, routed, extended, and loomed.
Next up I got some mounts for the LS from Dan Perlenfein. He even made me a custom trans mount for the TH400. These are very nice pieces, and I got them really quickly.
Got them set in the car, fit like a glove! (BTW they are not bolted down in any of these pics, just have the nut on the other side a few turns)
Next up I pulled the oil pan off my motor so I could drop it in and see what I am working with.
Bit of wishful thinking seeing of the truck intake would clear the hood. It wont.
So keep in mind that the mounts are not 100% bolted down yet. I need to get my trans from my buddy so I can get that in place before locking everything in place (just to take it all back out again). Once I have put the trans in then I can check a few things, and it can all come back out. Engine bay is going to get cleaned up, and the motor will get some TLC as well. I am still planning on trying to get it running and driving this year, but we will see if it happens. I am not one to let things be "good enough" so I may end up spending a bunch of money and time on the motor even though it will remain a stock bottom end.
Anyway I am really happy with the fitment, and how much space I have! This seems to be more room than I remember in an F-body (on the sides) even with a tubular K-Member. Should be able to get a big single in there no problem with a 4" down pipe to run out back. I am really glad I went LS!
Well time for a small update on the thread that nobody follows :) I got the trans, and a converter from my buddy a while back. Turns out the trans was shot, and needs a rebuild. That pretty much killed my plans for just getting it running this year. The good news is that I will be able to use it as a core to verify the trans mount, and hold everything in place so I can do all the fab work and wiring. I need to get un-lazy and move the car over in the garage so I can get the trans in one of these days. Its been hot as balls, and until I got my turbo there hasn't been much of a reason to bother getting it done. That excuse is out the window now though, since this came in last week
Its nothing special, just a Precision LS 7675, which is a cast wheel journal bearing 76mm. It should be able to max out the 5.3 though, so it will do for now. This weekend (it was hot as balls) I went out to the garage for a bit to try and get some idea where I was going to place the turbo so I can start getting an idea for a materials list. First up I got the radiator sitting in place (close enough)
These were the most obvious positions (turbo would need to be clocked differently for most) that I snapped some pics of not in any particular order.
Inside forward facing 45
TA style
Outside forward facing
That is really about all I got right now. I guess I also got the LS6 intake since my last update. That is still sitting on the truck steam ports which is why it isn't flat. I also got a set of non-EGR truck manifolds to use as the base of the turbo kit.
So right now I need to get everything mounted temporarily. That includes the trans, front accessories, exhaust manifolds, intake manifold, etc. Then I can lock down the turbo placement 100% and order material to start work. I also need to delete the ABS so I can mount the ECU over there and get started on the wiring. Well that's all for now, thanks for following along the journey of me seeing how dirty I can get my car.
Time for a small update, just because why not :)
I needed to get the trans in so I could check the fitment of the mount, as well as get everything locked into position for fabricating. Doing a trans by yourself is no fun, worse when you don't have a lift, and worse yet when you have to do some modifications for it to even fit. I ended up grabbing a trans jack from Harbor Freight to make my life a million times easier.
The only downside to it is that it is quite a bit taller than having the trans on my regular jack, but other than that it was SO MUCH BETTER. I could slowly move it into position and make small changes to angle and overall position with ease. Not to mention how nice it is to have the trans stable as you are moving around to get a good look at everything. It turns out it only needed a little massaging to get it bolted into place. Again, that is without a shield on it (or a bell) but I was glad I didn't have to spend hours hammering overhead.
Ignore the mess, the garage is in process of getting a lot of work as well.
Next up I wanted to see what I was working with on the exhaust manifolds.
Driver side is actually hitting the frame, but that is fine since I always planned on v-banding them anyway.
Plenty of space on the passenger side
Next up was trying to get an idea of what to do for accessories. There are about a million options out there these days. I started by trying to place the stock truck pieces just to get some idea.
Clearly those weren't going to work, but it was worth a shot. I have since figured out what I am going to do, but I will post more about that when I get all the parts. After that I reassembled the main fuse box under the hood. I need to patch where I cut for the procharger bracket, but the car is going to be outside for a bit while we finish the garage so I wanted to close off the fuses and wiring.
That was about it. Got the car back on the ground and pushed back out of the way for now.
Not really a crazy update, but progress none the less. While we are finishing the garage I will get the rest of the parts needed for the accessory drive setup. Once that is all in place I can start on fab work (FINALLY!), so hopefully the garage wont take too long. That's all I got for now, thanks for following along!
Nothing exciting, but parts have been coming in lately. I had to figure out and order up all of the front accessory drive components. Luckily there are a LOT of options for that kind of stuff these days. I ended up with a set of ICT billet brackets that will use a mix of F-body and Truck pieces.
While I am at it, I got all new everything else too since most of it required f-body pieces anyway.
New tensioner
New power steering pump pulley
I have a new water pump, but no pic of it. The new power steering pump will be here early next week as well. I haven't ordered an alternator yet, but I will later when I get a crank pulley.
Next up is some of the fabrication pieces for the turbo kit. I have only ordered the parts and pieces for the hot side so far.
All stainless steel T4 flange, four 2.5" 90's for the crossover, and a 4" 90 for the start of the down pipe
The stainless steel adapter from the weird 3-5/8" outlet of the turbo to 4" tubing.
I am still waiting on the 2.5" stainless v-band assemblies and the stainless O2 bung. I will also run another section of stainless on the downpipe, then a bellows, then adapt to aluminum for the rest of the exhaust. I probably wont start on that until after I do the cold side piping, which I will hopefully be able to start directly after the hot side fabrication is done. My garage is currently being finished, so I wont be able to start work for a couple weeks still, but its great to see parts coming in! That's all I got for now, thanks for following along.
Here are the 2.5" stainless steel v-band assemblies and the stainless steel O2 bung.
They are very nice with indexed flanges built in
Quick release clamps, another nice touch!
GM reman power steering pump came the other day as well
I was a bit surprised to see that the pump did not come with the pulley bolt, or the reservoir cap. Not a big deal, just slightly annoying. That is all I have for now. The garage is taking longer than expected, but I have also been working on the wife's car anyway. Sometime next week I will probably stock up on welding supplies so I can be ready to go. I should have enough to get started, but I know I will need some soon.
On to a bit of news, my garage is 90% done!! Paint went on last night, so now I can trim it this weekend and move everything back. Here are a couple quick pics.
For reference, here is a pic of the garage when we did our inspection (before we bought the house)
It had a single light bulb, and the opener was plugged into an outlet next to the switch with an extension cord duct taped to the drywall.
Here is a shot after we had added the sub panel, lights, and pulled down the drywall. I then insulated everything, and put up new 5/8" drywall.
I know not car related, but it has been a massive project that has delayed the car so I figured I would throw it in there now that I can see light at the end of that tunnel. Next update will be all car!
Well nothing too exciting to report still. I have been busy as hell finishing the garage, and getting our house ready for a party this weekend. I did however order up a bunch more material and pieces. I should have everything to build the intercooler piping except the intercooler (which is on backorder). I have all of the material to build my exhaust, but will probably need a couple v-bands so I can section it. Anyway, here are a couple pics.
Half stainless, half aluminum 4" V-band. I have two stainless steel 90's to come out of the turbo and get me to about the firewall, then it will be aluminum from there to the bumper. The other three pieces are 3" aluminum clamshell clamps for the intercooler piping.
Detail of the 4" v-band
And one of the clamshell clamps pulled apart.
I also got two boxes of piping as well. Those have a single stainless steel 4" 90, ten 3" aluminum 90's, six 4" aluminum 90's, two 4" aluminum 45's, two 2' long aluminum straight sections, a 3" silicone coupler, and a 3" to 3.5" silicone adapter with T-Bolt clamps. I am really hoping to start fabrication next weekend now that I should be done with all of these other projects. My pile of parts/material is starting to take up too much space!
Finally time for a bit of an update! After busting our asses on Friday night, the garage is now 99% done. All that really means for non OCD people is that I have more than 2 outlets (a LOT more) and don't need to drag extension cords all over! Let me back up a second, I needed to get the steering rack out of the car since it was wore out and I got a replacement for it. I also wanted to take the motor out to make taking the rack out easier, and so I could do some things with it on the stand. Thursday night I got under the car and pulled the trans.
Pretty easy to do with nothing really connected at all. Friday the car and the bike went outside while my buddy and I did the massive amount of electrical work in the garage. Saturday got mostly eaten up cleaning the garage from the previous nights thrashing. In the evening I got the car pulled back into the garage and was able to get back to work on it.
I let the snow melt off and dry up a bit before getting to work pulling the motor. Not terribly hard (again, nothing to disconnect or move), but kind of a pain in the ass since I have to come at it from the side.
So one of the first things I wanted to try, was see about fitting AC. I don't think I would run it this year, but if I could build with it in mind it would make things easy down the road. I grabbed a bracket and a junk compressor from a buddy so I could mock it up. He also had this manifold laying around, so I took that as well.
It is clearly a tight fit, but I think I could make it work. It pretty much kills running a 4" downpipe on the passenger side though, so I grabbed a piece of tubing to see what it looked like on the driver side.
Again, very tight but I should be able to make that work if I need to. I still haven't decided if I am going to mess with it or not, but its good to know about options. Next up was getting the front accessory drive all installed.
All laid out on the bench (minus the water pump since I forgot where I put it!)
Unfortunately I have the wrong tensioner, and I clearly still need parts (balancer, thermostat housing, alternator, etc.) but I can move forward with fabrication for now. Once that was done I pulled out the old rack.
Then I got the new poly bushing installed in the new rack
Then got it put in for now.
I am going to change the "EVO component", intermediate shaft, and outer tierods but its in the car so I can fabricate around it for now and keep it out of my way.
Then I got busy organizing all of my material so I could clear the space under my bench.
Pile of tubing!
Ahhhh thats better
At that point I was going to call it a night, but I decided to dive in and try and get something done. So I busted out the big boy grinder
Then I hacked off the end of the driver side manifold
Unfortunately, that was where I had to end it. Its been so long since I have welded, the batteries in the hood were dead! I am going to stop and get some on my way home today, and I am also waiting on some welding supplies. It was great to FINALLY be working on the car again! Like I said I am still unsure on the whole AC deal, but I think for now I am going to cut up that manifold and see whats up. I will also be putting the motor back in the car as soon as I get my new steering parts (that is a whole story on its own). Thats all I have for now, thanks as always for following along!
WHEW, that was a lot of info! I ended up having to pull the post from a site I had already done this same thing on. So I again apologize if it doesn't make a ton of sense since it was a catch up on a catch up. Going forward this will get updated in real time though. I have some tools and supplies coming this Friday, so hopefully I can get a good jump on some of the fab work. I guess we will see how it goes. Look for an update later in the weekend, or Monday. Hope you guys enjoy the build, I look forward to hearing from you guys.
Thanks,
Sean
Broke EF
1,760
4,468
The sticks
I worked on the car this weekend, and regretted every second of it. Lets rewind a bit to Saturday morning. We were in the driveway talking to the neighbors, and when they left I went to close the garage. When I did that my opener gave up. I manually closed the door, and then though you know I am going to need it open later today. I knew that it was very heavy (I dont think the spring was adjusted properly) so I wanted to make sure I could get it opened. When I did that it whipped up way past where it normally opens too. I left it until that night when I climbed up a ladder to close it. That was when I figured out that the roof of my car, which is up on the lift, acted as the stop for the door. Yesterday morning I moved everything out from under the car and lowered it down to see how bad it was.
It doesn't look dented, just scratched pretty bad. I am not happy about it, Ill just leave it at that.
It was also during this time that I found out my left arm was fucked. I have no idea what I did, but basically pulling toward me with my left arm is a no go. Its extremely painful, and it was so bad I couldn't even shift the ATV back into park with my left arm. This will come back later.
My neighbor had come by to help me move everything and get the door up (without smashing my car again) and we decided to get the car outside and pull the motor. While we were getting everything cleared out of the way, I was thinking (and asked) if we should pull the transmission first, or pull it all together. We decided to pull it all together since I had put it in all as one unit. So with it up on the lift we dropped the trans cross member, pulled the down pipe and then lowered it down. All ready to go!
He hopped in to steer, and I gave it a push. About half way down, loud bang and then I see the trail of trans fluid.
It ripped the plug right out of the pan along with the threads, and also cracked it. Again, not happy but its too late now. Right about here, he got called into work so I was on my own and committed. So I get everything all set up which means I forgot I need to pull the intercooler first, forgot I need to jack the car up slightly for the cherry picker to clear the crossmember, etc. I get the motor unbolted from the mounts, start to lift and then try to pull back on the cherry picker. This is when I am reminded in an excruciatingly painful way that my arm is damn near useless. I also realize that we are too far down the driveway making this all a lot harder. I usually do this in the garage where its smooth and relatively flat. So I do what anyone would do, hook the cherry picker to my ATV :)
This worked pretty well, except for the fact that the engine and trans together would not come out of the car. I forgot all about that nice new overflow I put on the trans, which I have now smashed into the cross member a couple times. I had to lower the motor back down and let it sit on the mounts nowhere near where they bolt on. I unbolted the trans and let it sit on the crossmember while I got the motor up and out without too much more drama.
Then I was left with just the trans and a bum arm.
I ended up just trying to lift it up and out. Surprise surprise, it didn't fit. I ended up having to lift the car up and slid it out of the side with my one good arm. That was about all I had energy for. I went back and finished mowing the dust that used to be grass then just cleaned everything up and put the car back on the lift.
I am going to order a new pan and overflow. I am sure both can be saved, but I just want to have it all nice and new (AGAIN). I will probably hold on to both old parts for future use in some other car. I also want to start ordering parts for the motor to get that thing finished up. I did get a few things for it recently, like a billet dumbell, new cam retention plate, and some ARP torque converter bolts. I will probably pull the front of the motor apart this week, and get the heads off so I can have them cleaned up. I also need to start working on the engine bay finally which is a big reason why I pulled it back out.
Anyway thats the story for this week. Thanks for following along as always.
Broke EF
1,760
4,468
The sticks
That sounds bad. It’s real common to pull the tendons in your elbow wrenching, that’s why I asked.
Yeah it hurt before I started on the car. I cant remember exactly what I did first, but something when I was making some breakfast stung a little. Then I went to move the ATV and that hurt really bad. So I started it and hopped on to move it and when I was done I couldn't put it back into park. The worst was trying to pull the cherry picker though. I tried to pull mainly with my right arm, but ended up pulling my left and that fucking hurt bad. So then the rest of the day I pretty much just didn't use my left arm at all.
Broke EF
1,760
4,468
The sticks
Damn, Im sure thats not the update you wanted to be giving this week. Take care of yourself man!
Yeah, you can say that again. But at least I made some forward progress?
Man I woulda stopped after the roof deal. I would have been too pissed to continue screwing things up. You need some wrenchin buddies close by when it comes to heavy lifting. Sucks being a 1 man show some times!
So I had planned on getting the motor and trans pulled this weekend since it was nice out. Unfortunately for me, the wife invited people by on Saturday so I couldn't work on it. When I found out the roof got damaged I pretty much lost my motivation. I had called my neighbor over to give me a hand with moving everything around in the garage. He was busy, and I have no patience so I did it myself and started to just cut the grass (not even really grass at this point) and wasn't going to mess with the car. He came by shortly after and wanted to see how bad it was so we lowered it down. Then he wanted to help me work on it so we started and you see the rest. Once we had it outside I was pretty much committed to at least get it apart and back into the garage. If things had gone better I would have done more for sure. Like I said, at least its progress?
Reactions: Rent Free
Rent Free
24,509
20,427
Nowheresville North Dakota
I can respect and appreciate the ambition. Ive been in that position before too. Im sure we all have cant seem to catch a break. Youre due for things to go smooth for a while now. LOL damn project cars. I wish I had more room to wrench myself Ive got a Thunderbird that needs alot of work. Unfortunately its gotta wait until were put of this townhome.
Broke EF
1,760
4,468
The sticks
I sure hope it starts going smoothly, I really want to make some serious progress on the car. Any progress lately has been hard fought, and its hard to keep slogging along like that. Every once in a while its nice to get a quick easy win to keep you going.
Believe it or not, I wish I had more room too. The wife and I were talking about that this weekend actually. The big thing is we used to have a shed, and now we don't. On top of that we also now have an ATV and a big ass mower to deal with on top of all of the other shed stuff. So regardless of our plan for the garage expansion and/or shop build, I think a shed is on the short list for next year. Moral of the story, just work on it anyway you never have enough room :)
Good news, the garage door guy just left. Got the opener fixed and added more tension on the spring. Bad news, he didn't say a word about the damage to my car. I'm not at home, but the wife said he didn't mention it. It used to be such a nice car :(
Broke EF
1,760
4,468
The sticks
Whats this, two weeks in a row?!!? That's right, I worked on the car two weeks in a row for the first time in a LONG time. Even though I really didn't want to, I started with welding. First up was the last piece of the hot side.
Then I clamped everything together so I could weld around the v-bands, and also finish up a couple small spots I didn't finish before. No pics of it on the bench, but I threw it all back on the motor really quick when I was done.
The passenger side manifold v-band is still only tacked, and the one on the hotside is not 100% yet either. But everything else is finished up. Not the best welds, but not the worst either. Hopefully it holds
Also chances are I am going to wrap all of it anyway to help keep heat down. I am thinking of adding some kind of flex or slip joint on the longer piece from the driver side manifold.
Anyway, once that was all done I moved onto the motor. To start I pulled off the accessories, and then the heads.
Looks a little rough in here :p
Then I tore down the heads in preparation of having them cleaned up before new seals, springs, and retainers.
Passenger side parts
And the driver side
And the driver side parts
I pulled the seals off too, but just tossed em.
The only real exciting part was that all the lifters are REALLY stuck. I need to figure that out, then I can pull the front cover, cam, oil pump etc. I will probably pop off a cap or two and see what the bearings look like since this motor is so rough. Hopefully it checks out well enough, and I can just clean everything up and start putting it together with all the shit I have laying around FOREVER.
Welp thats all for now. Wish me luck on making it 3 weeks in a row of progress :p
Broke EF
1,760
4,468
The sticks
I'm back with a small update!! I guess first up, I dropped the heads off to get cleaned up earlier in the week. Plan is just to have them cleaned, then new springs, retainers, and seals. I actually bought some springs a while back but now that I am doing a cam they aren't going to cut it.
So my plan for today was to get the rest of the motor torn down. I started by getting the lifters out, which took some doing. I just used brake clean and worked them around a bit till they came out.
Then I got ready to take the crank pulley off. This holder is pretty sweet.
It was about that time that I realized I'm a dumb ass, and dont have a puller for the crank pulley. I tried a little to get it off, but didn't want to fuck it up so I stopped. Right about then my engine stand plate showed up, so I got that set up real quick.
The stock setup sucks as you can see
MUCH better
After that I oiled the cylinders, and wiped them down some. They dont look great but the motor spins nice and easy. I am planning on cleaning it all up, and I MIGHT do a dingle ball hone and gap the rings. Not really sure yet though.
Once I figured out I was done with the motor for the day I worked on the ATV a bit. I wanted to build a push bar setup for it, and found out that there is a front receiver for it. I was skeptical about it, and was more worried about fitment since I have a plow mount and a winch as well. It took a lot of fucking around, but it did actually fit with no mods. It was just a mother fucker getting it done with everything in the way and my big ass hands.
The skid plate isnt bolted in, I need to trim more around some of the new bolts. I also need to put in my plow rope which is why there is nothing on the winch. I wasn't going to swap the cable yet but it was making my life harder so I just took it off. Now that I have something on the ATV I guess I can go ahead and put a receiver on the SC so I can use it to push, and also for a trailer for drag week.
Thats all for this week. I wasn't even sure I would get any time to work on it so I am glad I got something done. I am not so sure I will be able to get back on it next weekend. We are getting ready to paint the whole house so I have a lot of BS to do to get ready for that. I am gonna try and sneak in some time with the car though.
Welp, thanks for following along!
Broke EF
1,760
4,468
The sticks
Got this cheap puller the other day. Hopefully it works and I can get the crank pulley off without too much drama.
I may try and get it done tonight just because. I am a little torn on if I should actually tear it all the way down and do new bearings and rings. I did that on my old motor, which I sold, but it wasn't cheap. This motor is in better condition (in some ways) but still not great. I am going to at least clean it up and make it look presentable.
Reactions: IDAFC21
Broke EF
1,760
4,468
The sticks
Damn how'd I miss the update. Looks like some decent progress!
I actually pulled the crank pulley last night.
Not exactly major progress, but it has needed to be done for a while now. I also ordered up the springs, retainers, and valve seals for my heads. They are drop shipping to the shop, so that should all be done soonish.
Reactions: IDAFC21
Broke EF
1,760
4,468
The sticks
Well not much to report today. I worked on the motor for a little bit on Saturday with plans to do more Sunday. Unfortunately I ended up busy the entire day Sunday and didn't get back to the car. That's how it goes sometimes though.
I started by taking off the front cover, now that the crank pulley is off. The chain was nice and sloppy, but I kind of expected that. I pulled off the oil pump, timing chain, and then pulled out the cam.
The keen among you will notice the motor is flipped over. That was because I pulled off the truck windage tray as well.
And here is the pile of parts I took off/out
That was it, that was all I got done. I stared at it for a bit thinking if I should pull a cap or two and look at the bearings. I already have a new oil pump, windage tray, pick up (and brace), pan, front cover seal, cam retaining plate, hardware etc. I need to order up my cam and timing set, then weld a drain for the turbo somewhere. I am un-decided if I want to go to the pan or the front cover. I also clearly need to clean up that front cover as well as the rest of the motor and hit it with some paint.
The parts for my heads showed up at the shop today, so hopefully he gets those knocked out for me pretty quick. Thats all I got for now. I want to try and keep moving on this all, but we also have some bigger house stuff happening which may pull me away for a few weeks. I am going to try and balance working on both, but the house stuff is on a clock so it gets priority. Before anyone asks, no its nothing exciting like a shop or anything cool :(
Fingers crossed I have a good update next weekend!!!
Broke EF
1,760
4,468
The sticks
No work has been done yet, but I did swing by and pick up my heads today! I am pretty excited so here we go.
Turns out they were a little worse for wear, but first up I brought my intake manifold with so he could run it through the parts washer. He had to do it like 3 times to get all the shit out of it. They were hard on that thing out in Kuwait I guess!
Next up were the heads. So I knew I was doing cleaning, fixing 3 broken studs, new springs, retainers, and seals. We did all of that, plus new intake valves, a valve job, new keepers, and surfaced them. I am really happy with how they turned out!!!
I know its nothing fancy, but they look a lot better than I expected! Glad I had them done up. I wish I could swing having the short block all done like I did my last one, but just don't have the funds right now.
Well thats all, I was just excited. Hopefully I am able to get some work done with the car tomorrow or Sunday. Stay tuned :)
