🔧 BUILD Broke EF turbo LS SC400 Build
I may have never posted on here before, but for some reason I am inspired to post my build up here. I am going to copy and paste from another site to get us all up to speed. I will try and clean up anything that was specific to the thread I am pulling from. Now that I am getting started on the main fab work I will update this thread in real time.
For anyone who doesn't want to read it all here is the short version. I bought the car on a whim in June of 2016. It is a 1993 SC400 that was from this area, and was meticulously maintained at the dealer. I was going to stay with the original 1UZ so you will see I started installing a procharger on it. I ended up selling off the stock motor, trans, ecu and harness to a local guy and got an iron gen 3 5.3 motor. I am doing a Precision LS-7675 turbo with a truck manifold based kit (more or less). It will be backed up by a TH400, and for now will use a stock ECU with HP Tuners.
Alright, time for the massive dump of info.
A couple years ago I picked up a 1993 SC400. I wasn't really looking for a car, but a late night search found this one, and I have always liked them. I decided to go down and give it a look in person, and it was even cleaner than it looked in the pics so I bought it. Here are a couple pics of when I first got it.
I wont bore you with all of the middle shit, just hit you with the highlights.
I removed a couple tons of wiring that used to be an alarm system.
I had the gauge cluster fixed/updated with white LED's.
Fixed up the wiring that was kind of hacked up from the alarm. Changed the steering wheel, etc. etc.
I then updated the climate control, and put in a nice head unit.
Just a bunch of little changes and fixing up small things here and there. The car was extremely well maintained and really did not NEED much. My plan was always to make it fast of course, and do drag week with it. The factory 1UZ motor is a very good starting point and can make some really solid HP. The stock trans can be built to live as well. Packaging was kind of a nightmare as you can see, but other than that it was a good option.
I ended up stumbling upon a great deal on a procharger kit that was actually on an SC400 locally. It was a P1SC that came with some shitty piping, a way too small intercooler, but a Tial blow off valve that actually had the right spring it it! I started installing that setup.
You can see one of the things that was constantly in the back of my mind for making this a drag week car. Look how complicated that engine looks! If I had a problem on the road not only would parts be an issue, but just the time to do simple repairs is a nightmare. For example the starter is under the intake manifold in the valley.
So when a local kid hurt the motor in his SC I offered mine up to get him back on the road since that is his only car. We struck a deal and I ripped that shit out the next day.
It happened to work out that a 5.3 LS came up for sale for the same money I just sold my old motor for, so I jumped on it.
Its update time! Nothing really exciting, but I have been slowly chipping away at things.
First up was wiring. I am planning on using the stock ECU for a little bit with HP Tuners, so I had some wiring work to do.
Harness as I got it with the motor
Stripped of all of the brittle loom and crappy electrical tape.
Unfortunately I ended up having to move it around after I had stripped off all of the crap, and it got pretty tangled.
So I decided to just fully depin everything since I only need a few things from that mess.
Here is the pile of junk I didn't need from that harness. There is actually a bit more, but that is 99.99% of it.
And here is everything all apart, ready to be cleaned, routed, extended, and loomed.
Next up I got some mounts for the LS from Dan Perlenfein. He even made me a custom trans mount for the TH400. These are very nice pieces, and I got them really quickly.
Got them set in the car, fit like a glove! (BTW they are not bolted down in any of these pics, just have the nut on the other side a few turns)
Next up I pulled the oil pan off my motor so I could drop it in and see what I am working with.
Bit of wishful thinking seeing of the truck intake would clear the hood. It wont.
So keep in mind that the mounts are not 100% bolted down yet. I need to get my trans from my buddy so I can get that in place before locking everything in place (just to take it all back out again). Once I have put the trans in then I can check a few things, and it can all come back out. Engine bay is going to get cleaned up, and the motor will get some TLC as well. I am still planning on trying to get it running and driving this year, but we will see if it happens. I am not one to let things be "good enough" so I may end up spending a bunch of money and time on the motor even though it will remain a stock bottom end.
Anyway I am really happy with the fitment, and how much space I have! This seems to be more room than I remember in an F-body (on the sides) even with a tubular K-Member. Should be able to get a big single in there no problem with a 4" down pipe to run out back. I am really glad I went LS!
Well time for a small update on the thread that nobody follows :) I got the trans, and a converter from my buddy a while back. Turns out the trans was shot, and needs a rebuild. That pretty much killed my plans for just getting it running this year. The good news is that I will be able to use it as a core to verify the trans mount, and hold everything in place so I can do all the fab work and wiring. I need to get un-lazy and move the car over in the garage so I can get the trans in one of these days. Its been hot as balls, and until I got my turbo there hasn't been much of a reason to bother getting it done. That excuse is out the window now though, since this came in last week
Its nothing special, just a Precision LS 7675, which is a cast wheel journal bearing 76mm. It should be able to max out the 5.3 though, so it will do for now. This weekend (it was hot as balls) I went out to the garage for a bit to try and get some idea where I was going to place the turbo so I can start getting an idea for a materials list. First up I got the radiator sitting in place (close enough)
These were the most obvious positions (turbo would need to be clocked differently for most) that I snapped some pics of not in any particular order.
Inside forward facing 45
TA style
Outside forward facing
That is really about all I got right now. I guess I also got the LS6 intake since my last update. That is still sitting on the truck steam ports which is why it isn't flat. I also got a set of non-EGR truck manifolds to use as the base of the turbo kit.
So right now I need to get everything mounted temporarily. That includes the trans, front accessories, exhaust manifolds, intake manifold, etc. Then I can lock down the turbo placement 100% and order material to start work. I also need to delete the ABS so I can mount the ECU over there and get started on the wiring. Well that's all for now, thanks for following along the journey of me seeing how dirty I can get my car.
Time for a small update, just because why not :)
I needed to get the trans in so I could check the fitment of the mount, as well as get everything locked into position for fabricating. Doing a trans by yourself is no fun, worse when you don't have a lift, and worse yet when you have to do some modifications for it to even fit. I ended up grabbing a trans jack from Harbor Freight to make my life a million times easier.
The only downside to it is that it is quite a bit taller than having the trans on my regular jack, but other than that it was SO MUCH BETTER. I could slowly move it into position and make small changes to angle and overall position with ease. Not to mention how nice it is to have the trans stable as you are moving around to get a good look at everything. It turns out it only needed a little massaging to get it bolted into place. Again, that is without a shield on it (or a bell) but I was glad I didn't have to spend hours hammering overhead.
Ignore the mess, the garage is in process of getting a lot of work as well.
Next up I wanted to see what I was working with on the exhaust manifolds.
Driver side is actually hitting the frame, but that is fine since I always planned on v-banding them anyway.
Plenty of space on the passenger side
Next up was trying to get an idea of what to do for accessories. There are about a million options out there these days. I started by trying to place the stock truck pieces just to get some idea.
Clearly those weren't going to work, but it was worth a shot. I have since figured out what I am going to do, but I will post more about that when I get all the parts. After that I reassembled the main fuse box under the hood. I need to patch where I cut for the procharger bracket, but the car is going to be outside for a bit while we finish the garage so I wanted to close off the fuses and wiring.
That was about it. Got the car back on the ground and pushed back out of the way for now.
Not really a crazy update, but progress none the less. While we are finishing the garage I will get the rest of the parts needed for the accessory drive setup. Once that is all in place I can start on fab work (FINALLY!), so hopefully the garage wont take too long. That's all I got for now, thanks for following along!
Nothing exciting, but parts have been coming in lately. I had to figure out and order up all of the front accessory drive components. Luckily there are a LOT of options for that kind of stuff these days. I ended up with a set of ICT billet brackets that will use a mix of F-body and Truck pieces.
While I am at it, I got all new everything else too since most of it required f-body pieces anyway.
New tensioner
New power steering pump pulley
I have a new water pump, but no pic of it. The new power steering pump will be here early next week as well. I haven't ordered an alternator yet, but I will later when I get a crank pulley.
Next up is some of the fabrication pieces for the turbo kit. I have only ordered the parts and pieces for the hot side so far.
All stainless steel T4 flange, four 2.5" 90's for the crossover, and a 4" 90 for the start of the down pipe
The stainless steel adapter from the weird 3-5/8" outlet of the turbo to 4" tubing.
I am still waiting on the 2.5" stainless v-band assemblies and the stainless O2 bung. I will also run another section of stainless on the downpipe, then a bellows, then adapt to aluminum for the rest of the exhaust. I probably wont start on that until after I do the cold side piping, which I will hopefully be able to start directly after the hot side fabrication is done. My garage is currently being finished, so I wont be able to start work for a couple weeks still, but its great to see parts coming in! That's all I got for now, thanks for following along.
Here are the 2.5" stainless steel v-band assemblies and the stainless steel O2 bung.
They are very nice with indexed flanges built in
Quick release clamps, another nice touch!
GM reman power steering pump came the other day as well
I was a bit surprised to see that the pump did not come with the pulley bolt, or the reservoir cap. Not a big deal, just slightly annoying. That is all I have for now. The garage is taking longer than expected, but I have also been working on the wife's car anyway. Sometime next week I will probably stock up on welding supplies so I can be ready to go. I should have enough to get started, but I know I will need some soon.
On to a bit of news, my garage is 90% done!! Paint went on last night, so now I can trim it this weekend and move everything back. Here are a couple quick pics.
For reference, here is a pic of the garage when we did our inspection (before we bought the house)
It had a single light bulb, and the opener was plugged into an outlet next to the switch with an extension cord duct taped to the drywall.
Here is a shot after we had added the sub panel, lights, and pulled down the drywall. I then insulated everything, and put up new 5/8" drywall.
I know not car related, but it has been a massive project that has delayed the car so I figured I would throw it in there now that I can see light at the end of that tunnel. Next update will be all car!
Well nothing too exciting to report still. I have been busy as hell finishing the garage, and getting our house ready for a party this weekend. I did however order up a bunch more material and pieces. I should have everything to build the intercooler piping except the intercooler (which is on backorder). I have all of the material to build my exhaust, but will probably need a couple v-bands so I can section it. Anyway, here are a couple pics.
Half stainless, half aluminum 4" V-band. I have two stainless steel 90's to come out of the turbo and get me to about the firewall, then it will be aluminum from there to the bumper. The other three pieces are 3" aluminum clamshell clamps for the intercooler piping.
Detail of the 4" v-band
And one of the clamshell clamps pulled apart.
I also got two boxes of piping as well. Those have a single stainless steel 4" 90, ten 3" aluminum 90's, six 4" aluminum 90's, two 4" aluminum 45's, two 2' long aluminum straight sections, a 3" silicone coupler, and a 3" to 3.5" silicone adapter with T-Bolt clamps. I am really hoping to start fabrication next weekend now that I should be done with all of these other projects. My pile of parts/material is starting to take up too much space!
Finally time for a bit of an update! After busting our asses on Friday night, the garage is now 99% done. All that really means for non OCD people is that I have more than 2 outlets (a LOT more) and don't need to drag extension cords all over! Let me back up a second, I needed to get the steering rack out of the car since it was wore out and I got a replacement for it. I also wanted to take the motor out to make taking the rack out easier, and so I could do some things with it on the stand. Thursday night I got under the car and pulled the trans.
Pretty easy to do with nothing really connected at all. Friday the car and the bike went outside while my buddy and I did the massive amount of electrical work in the garage. Saturday got mostly eaten up cleaning the garage from the previous nights thrashing. In the evening I got the car pulled back into the garage and was able to get back to work on it.
I let the snow melt off and dry up a bit before getting to work pulling the motor. Not terribly hard (again, nothing to disconnect or move), but kind of a pain in the ass since I have to come at it from the side.
So one of the first things I wanted to try, was see about fitting AC. I don't think I would run it this year, but if I could build with it in mind it would make things easy down the road. I grabbed a bracket and a junk compressor from a buddy so I could mock it up. He also had this manifold laying around, so I took that as well.
It is clearly a tight fit, but I think I could make it work. It pretty much kills running a 4" downpipe on the passenger side though, so I grabbed a piece of tubing to see what it looked like on the driver side.
Again, very tight but I should be able to make that work if I need to. I still haven't decided if I am going to mess with it or not, but its good to know about options. Next up was getting the front accessory drive all installed.
All laid out on the bench (minus the water pump since I forgot where I put it!)
Unfortunately I have the wrong tensioner, and I clearly still need parts (balancer, thermostat housing, alternator, etc.) but I can move forward with fabrication for now. Once that was done I pulled out the old rack.
Then I got the new poly bushing installed in the new rack
Then got it put in for now.
I am going to change the "EVO component", intermediate shaft, and outer tierods but its in the car so I can fabricate around it for now and keep it out of my way.
Then I got busy organizing all of my material so I could clear the space under my bench.
Pile of tubing!
Ahhhh thats better
At that point I was going to call it a night, but I decided to dive in and try and get something done. So I busted out the big boy grinder
Then I hacked off the end of the driver side manifold
Unfortunately, that was where I had to end it. Its been so long since I have welded, the batteries in the hood were dead! I am going to stop and get some on my way home today, and I am also waiting on some welding supplies. It was great to FINALLY be working on the car again! Like I said I am still unsure on the whole AC deal, but I think for now I am going to cut up that manifold and see whats up. I will also be putting the motor back in the car as soon as I get my new steering parts (that is a whole story on its own). Thats all I have for now, thanks as always for following along!
WHEW, that was a lot of info! I ended up having to pull the post from a site I had already done this same thing on. So I again apologize if it doesn't make a ton of sense since it was a catch up on a catch up. Going forward this will get updated in real time though. I have some tools and supplies coming this Friday, so hopefully I can get a good jump on some of the fab work. I guess we will see how it goes. Look for an update later in the weekend, or Monday. Hope you guys enjoy the build, I look forward to hearing from you guys.
Thanks,
Sean
Broke EF
1,768
4,492
The sticks
Wooo boy you did a lot of work on the car I can tell.
Apologies if you already answered this but what is your plan for your exhaust?
Its been a lot of "small" things that just take a ton of time. I still have so much of that kind of stuff left to do too.
This year my plan is probably just what you see there since its so late in the year already. I want to run a full 4" from the turbo all the way out of the bumper. I may have to go smaller, but we will see. It gets tight around the starter is the biggest issue.
  • Love
Reactions: Pro Stock John
Broke EF
1,768
4,492
The sticks
It has happened!!! I drove the car under its own power today. Just out of the garage, down the driveway.
And then back in the garage and up onto the lift!!
I dont feel like looking it up, but its been over 3 years since it has moved under its own power. In that time I am pretty sure I have never been in the driver seat to move it. I usually do it from outside the car, or have someone else steer it. Of course it still needs a lot of work, and it leaked all over my driveway, but thats fine by me :D
My neighbor got video of it, so I should have something sooner or later to prove it moves LOL. Now that its back up on the lift I can change the oil, adress some small leaks, finish some wiring, bleed the brakes, and so on and so on. I cant wait to start putting miles on it!!
Broke EF
1,768
4,492
The sticks
It's always one step forward, two steps back. I wanted to make the track day, but I knew that was pretty unlikely. Then I saw the announcement for tomorrow's cara and coffee and thought "hey I can probably make that!". So I spent today getting things more finished in anticipation of driving to Elgin tomorrow morning. I even called and started my insurance.
Then I took it for a drive around the block. I saw some smoke and the some spray on the windshield. Turns out my power steering pump decided to blow apart? It's just dumping fluid out of the shaft around the pulley and making a massive mess.
The only thing I can think of is the lines on the rack are backwards? I don't even know if that would do it. Anyway I just went inside. Fuck this car.
Broke EF
1,768
4,492
The sticks
Whew, what a weekend!!! I stayed up till around 1 last night (this morniing) putting it all back together and getting ready. I ended up putting in a new pump, bled it, kinda sorta aligned it (WAY WAY off) locked down the tierods and everything, fabricated the lower IC pipe, headlights back in, and some other small shit. I was back up at 6AM and back in the garage at 7 working on some more stuff. I got the trans topped off and then I was finally ready for its first real drive to quickly rinse it down at the local car wash.
After that I ran home and cheaned up a bit, before running out and getting gas and heading to Elgin.
All in all the car did great! It has some bugs to work out, but it made it there and back. Its loud, hot, and full of fumes, and I love it :D
Broke EF
1,768
4,492
The sticks
Random mid week update time :D
I am going to gloss over the accident for now. Lets talk about whats been happening with the car. The big thing is I have been fighting the car running hot since day one. I have tried a handful of things, and so far nothing is helping. I think I finally figured it out, not running a thermostat. My waterpump (F-Body) has a built in bypass and its just wide open with no stat. The housing I had on the car was designed for a normal SBC/BBC thermostat, which I did try. So I orderd up a Motion Raceworks housing.
Unfortunately I needed to get another stat for the gasket. That worked out fine though since it was raining today, I couldnt take it out to test it anyway. Tomorrow the plan is to put it back together, take it out for some spirited driving and see how it does. If all goes well, I am planning on taking it to work Thursday and then to GLD after to make some passes. For this first trip out I am planning on just foot braking at the most. No trans brake, no boost controller yet. Also to try and help out on the cooling I got some plates from LRB speed to direct the air to the radiator.
I also got the center trim piece to make it a little easier around the shifter. I am going to powder coat all that stuff, try to make it a little better looking. Besides that I got around to putting the interior back together.
Thats kinda about it for now. I am really hoping that the thermostat fixes my cooling problems. I also have a monster SPAL fan to install too, but I want to see what it does without it first. Putting the interior back together has reminded me that I really REALLY want to rip out the wiring and re-do the car bumper to bumper. That will probably happen over the winter along with a cage. Next up on the list (tomorrow) is get the passenger window rolled up (not sure whats wrong there), and get the temporary fender and headlight installed. That seems like enough random babling. Here are some random pics :D
32,622
16,051
You have to run the proper thermostat in a mixing cooling system used on 98% of newer engines.
In the old days the thermostat would open all the hot water would leave the block and a whole bunch of cold water would rush in and caused expansion problems that would lead to scrubbing of head gaskets and Gasket failure.
Modern engines use thermal mixing system that mixes the cold water from the radiator with the hot water in the block leading into the water pump Inlet so that it is homogenized and then put into the block to prevent thermal shock issues.
Reactions: Jon01 and Broke EF
